⚡ TL;DR
Use Split Inboxes to organize your inbox and prioritize important emails first.
- Desktop: Click Settings ⚙️ → Split Inbox Library to see a list of built-in Split Inboxes. To add to VIP, Team, or News, hit Cmd+K (Mac) or Ctrl+K (Windows) → Add to Split.
- Mobile: Two-finger tap then type Split Inbox Library to see built-in Split Inboxes. To add to VIP, Team, or News, do a two-finger tap, then type Add to Split.
- To help you reach Inbox Zero, the total number of conversations appears beside each Split Inbox.
- Default and Custom Split Inboxes are available.
- When setting up Split Inboxes, aim for no more than seven for optimal productivity.
Table of Contents
- Enable Split Inbox
- Edit Split Inbox
- Add to VIP, Team, or News
- Common Default Split Inboxes
- Custom Split Inbox
- FAQs
Overview
Split Inboxes are intentional sections at the top of your inbox that help you stay focused and organized. They help you prioritize important emails and batch process similar messages.
To help you reach Inbox Zero, the total number of conversations appear beside each Split Inbox. If you've reached Inbox Zero in a Split Inbox or if the total exceeds 999, the count will not be displayed.
To navigate between Split Inboxes on Desktop, hit Tab to move right and Shift+Tab to move left. On Mobile, simply tap the Split Inbox name at the bottom of the screen.
Enable Split Inbox
Superhuman Mail provides a variety of default Split Inboxes so you can easily create priority in your inbox.
To see a list of default Split Inboxes:
- Click Settings ⚙️ → Split Inbox Library.
- Select the Split Inbox you would like to add to your inbox.
- Select Turn on Split Inbox.
Mobile
To see a list of default Split Inboxes on Mobile:
- Pull down from the top of the inbox for Superhuman Command, then swipe right — like you're making an "L."
- Type Split Inbox Library.
- Under General, tap the Split Inbox you would like to add to your inbox.
- Tap Turn On.
Once enabled, messages that match the criteria will automatically go to that Split Inbox.
💡 Tip: Learn more about the Split Inbox Library.
Edit Split Inbox
You can edit, hide, turn off, or reorder default Split Inboxes.
To edit, hide, or turn off a Split Inbox:
- Click Settings ⚙️ → Split Inbox.
- Click on a Split Inbox to make edits.
- To hide a Split Inbox, check the box beside Hide this Split Inbox when empty. This hides the Split Inbox when it's empty.
Note: You cannot hide Inbox, Important, or Other.
- To turn off a Split Inbox entirely, click Turn off Split Inboxes.
Note: If you turn off a Split Inbox, its conversations move back to Inbox, Important, or Other, and the Split Inbox moves to the Inactive tab.
To reorder your Split Inboxes, click and drag the hamburger icon (three horizontal lines).
Mobile
- Type Split Inbox Settings.
- Select the account where you want to edit, hide, or turn off the Split Inbox.
- Tap the Split Inbox you want to edit.
- To hide a Split Inbox, turn on Hide this Split Inbox when empty. This hides the Split Inbox when it's empty.
- To turn off a Split Inbox entirely, tap Turn Off Split Inbox.
To reorder your Split Inboxes, tap Edit in the top right corner, then tap and drag the hamburger icon (three horizontal lines).
You can add certain email addresses or domains to VIP, Team, or News.
- Select the conversation you would like to add to a Split Inbox.
- Hit Cmd+K or Ctrl+K → Add to Split Inbox.
- Use the Up and Down arrow keys to select your definition, then hit Enter.
- Select the target Split Inbox and hit Enter.
Mobile
- Tap the conversation you would like to add to a Split Inbox.
- Pull down from the top of the inbox, then type Add to Split.
- Tap to select the criteria you'd like to add.
- Tap to select the target Split Inbox.
💡 Tip: If you'd prefer messages to also appear in Important or Other, check the box beside Also show conversations that match this Split Inbox in Important or Other.
Below are the most commonly used Split Inboxes in our library.
- Important • Other — Important contains all person-to-person and high-priority messages, while Other contains emails sent to mailing lists, and automated messages such as marketing, social, and automatic updates. This setup minimizes distractions and helps you focus on key messages first. If messages are mis-categorized in these Split Inboxes, learn how to move them between Important and Other.
- Shared – Includes all conversations shared using Cmd+K or Ctrl+K → Share Conversation or Comment, helping you collaborate more efficiently within your team.
- Team — Contains all conversations with people who share your domain, making it easier to stay responsive as a manager or teammate. You can choose whether Team emails should also appear in Important.
- VIP — Captures all conversations involving people you classify as VIPs, ensuring you never miss their messages. VIP emails also appear in Important by default, unless you disable this option.
- News — Contains newsletters you've added to stay informed and up to date.
- Calendar — Includes emails from notifications@calendly.com, calendar-notification@google.com, and emails with calendar invite files (.ICS files) so you can easily manage all your calendar updates in one place.
Custom Split Inbox
Learn how to customize your own Split Inbox.
I want my messages to appear in its Split Inbox and Important/Other.
To have messages duplicate in Important/Other, click Settings ⚙️ → Split Inbox, then click ⚙️ next to the Split Inbox. Check the box beside Also show conversations that match this Split Inbox in Important or Other.
How many Split Inboxes can I have?
Though there isn't a limit to how many Split Inboxes you can enable, we recommend no more than seven for optimal productivity. Having more than that can slow you down as it creates more places to check.
Are Split Inboxes like folders?
No. Split Inboxes should contain emails that still require action. Folders, on the other hand, are best for storing messages you've already actioned.
For more productivity tips, join an expert-led webinar.
Can my Split Inboxes reflect the unread count instead of the total count?
There isn't a way to change the total count to show unread only, however, you can filter unread conversations by hitting Cmd+K or Ctrl+K → Filter Conversations.
I can't find one of my Split Inboxes. Where did it go?
If a Split Inbox is set to "Hide when empty" and has no messages, it disappears from your Split Inbox bar. You can still access it by hitting Cmd+K or Ctrl+K → go to [Split Inbox Name]. When you navigate away from it, it will hide again automatically.
