Coda is becoming Superhuman Docs! We’re giving Coda powerful new AI capabilities, new ways to work with your data, a fresh new look, and more, all under a new name to match. It's the docs, tables, and building blocks you rely on every day, now officially as part of the Superhuman family. Everything you've built comes with you, there’s nothing to migrate or export.
What you need to know to get ready
  • Superhuman Docs has a new home on the web: docs.superhuman.com. Your existing coda.io links will redirect there automatically.
  • The first time you open Docs on a new browser or device, you'll do one quick sync to bring over your settings and any offline edits. After that, you’re all set.
  • Your content, settings, and pricing stay the same.
  • You'll start seeing the Superhuman Docs name in emails, on our website, and other places you used to see Coda.
  • If your organization uses a firewall, we suggest adding superhuman.com to your allow list and removing any blocks to that domain. Learn more here.
When it's happening
We're rolling out in waves starting July 7th, so you may see the change on the 7th or 8th depending on your region. We'll share the full story, and everything that's new, in our official announcement on July 8th.
Can't wait to show you what we've been building!
Why is Coda changing its name?
Superhuman Docs is the next chapter for Coda as part of the Superhuman product family. The new name reflects a closer alignment with the Superhuman brand and a renewed focus on helping teams and AI work better together.
Will my pricing or plan change?
No. Your plan and pricing stay the same.
If you choose to upgrade, you may be eligible for a Superhuman bundle - which includes Docs, Go, Mail, and Grammarly. But you can also remain on your existing plan if you prefer.
Will any features or functionality be removed?
No features or functionality are going away. Everything you rely on in Coda today will be there when you open Superhuman Docs after the transition. The change is purely additive - along with the new name and fresh look, we’re introducing some exciting new capabilities and features.
Will I need to update or reinstall the mobile app?
The existing Coda apps on iOS and Android will become the new Superhuman Docs apps. If you already have the Coda app installed, you'll receive an update to it through the App Store or Google Play. If you don't have it installed, just search your app store for Superhuman Docs (searching Coda still works too).
