Learn how to purchase an additional Pack outside of Superhuman Docs' pricing tiers. Also find instructions on cancelling and trialing Packs.
As part of Superhuman Docs Pack Marketplace (formerly "Coda Pack Marketplace"), customers on the Docs Pro and Team plans can purchase Packs individually, separate from Packs bundled into the pricing tiers. This article will explain how to purchase, cancel, or trial individual Packs, and will address key questions to make sure you are best equipped to make a purchase decision.
Packs included in your pricing tier
Superhuman Docs offers several different pricing tiers, including Free, Pro, Team, and Enterprise. You can read all about the different tiers and what’s included in each on our pricing page. On that page, you’ll see the list of Packs included - at no additional cost - for each tier.
📣 Is your Docs workspace part of a Superhuman bundle? If so, you might be wondering which Packs are included in each Superhuman tier. The Superhuman Business tier will offer access to all Packs included in Docs Team tier. All other Superhuman tiers align with Docs tiers as expected.
But what if you’re on Docs' Pro or Team tier and want to purchase an individual Pack that’s only included in a higher tier? Good news - you may be able to purchase additional Packs individually, without having to upgrade to a higher tier. The next section will explain how.
Purchase a Pack
ℹ️ Note that you must be a workspace admin on a Pro or Team plan in order to purchase Packs individually.
If your Docs workspace was created through Superhuman or is part of a Superhuman bundle, you will not be able to purchase individual Packs at this time. Instead, you may consider upgrading your Superhuman plan to get access to additional Packs.
To purchase an additional Pack, follow these steps:
  1. Find the Pack you wish to purchase by searching the Pack gallery
  2. Once you’ve found and selected that Pack listing, click the Buy button.
  3. You’ll then see a confirmation page, including some details about the monthly cost (see info about how billing works below). Click Confirm payment to complete purchase.
Gif demonstrating a user purchasing the Microsoft Teams pack.
You’ve now purchased the Pack! Purchasing a Pack makes it accessible to the entire workspace. This means doc editors can also use Packs despite not being able to make docs.
Packs are charged on a per Doc Maker, per month basis. For instance, let’s say you purchase the Figma Pack. This Pack costs $10 per Doc Maker, per month. Your workspace has two Doc Makers. Therefore the workspace will be charged $20 for the Figma Pack per month. This $20 would be added to your invoice every month.
Note that we do not currently support annual billing for Packs.
Cancel a Pack subscription
If you can to cancel a Pack subscription, just follow the steps below. Note that only workspace admins can take this action.
  1. Go to docs.superhuman.com
  2. Click on Admin settings in the left panel
  3. Search for or scroll to the Packs section, and select the Workspace Pack subscriptions page
  4. Under Subscriptions, you'll see all the Packs your workspace is subscribed to. Find the Pack in question, click on it to expand, then select Unsubscribe.
  5. Click End subscription to confirm.
Trial a Pack before purchasing
Most Packs will offer a 14 day trial per doc. These trials will offer unmitigated access to the Pack for this 14 day period. No quotas or limitations!
Any editor or Doc Maker in a workspace can initiate a trial by simply adding the Pack to a doc, then selecting the Try it option.
Gif showing user starting a pack trial.
A per-doc trial means the trial will be initiated per doc that the Pack is installed in. You can see how many days are left in the trial by clicking on Insert, then Packs, and finding the specific Pack under Installed Packs. You will also receive warning messages indicating when the trial has expired.
Image showing a pack with text that indicates days left in trial.
A Pack trial expiration will not affect the functionality of your doc. Only the Pack will be disabled upon completion of the trial, assuming you do not purchase it before then.
Note: We reserve the right to curtail abuse of Pack trials such as continuing trialling a Pack over and over in the same workspace with no intention to purchase.
Can anyone in my workspace buy a Pack?
No, only workspace admins (aka Doc Maker (Workspace admin)) may purchase Packs. The Pack will then be available to Doc Makers and editors in the workspace.
Note that Doc Makers and editors can trial Packs, assuming the Pack Maker has enabled trials.
How does billing work for purchased Packs?
Additional Packs are purchased as a monthly subscription. Packs are charged on a per Doc Maker, per month basis. So you can multiply whatever cost is listed on the Pack page by the number of Doc Makers in your workspace. You will also see the monthly cost previewed for you when you confirm your purchase.
Do you offer annual billing for Packs?
No - Pack subscriptions can only be billed on a monthly basis.
Where can I go to learn more about the security of Packs?
Check out this article that covers this topic in depth.
Can I purchase individual Packs if my Docs workspace is part of a Superhuman bundle?
Unfortunately, if your Docs workspace is part of a Superhuman bundle, you will not be able to purchase a la carte Packs at this time. Instead, you may want to consider upgrading your Superhuman plan to get access to the next level of included Packs.
Note that you will still be able to trial individual Packs that aren't already included in your pricing tier.
