Tap, Type, Find
Great work learning how to swipe around Superhuman Mail, customize your inbox, and manage your emails efficiently 😮‍💨
Now, it’s time to learn how to search for what you need in seconds, whether it’s an attachment from last week or a message from years ago.
Try It Now
  1. From the main inbox, pull down from the top of the inbox to search.
  2. Type your query, then tap search to start a search across your inbox and folders.
💡 Tip: The most common operators (such as to: from:) appear just below the search bar. Tap any operator to quickly run a targeted search!
Ask AI (Business & Enterprise Plans)
Let Ask AI do the hard work for you! Say goodbye to remembering senders, guessing keywords, and scanning subject lines.
Try It Now (optional)
  1. You must first be on the Business or Enterprise Plan.
  2. From the main inbox, pull down from the top of the inbox to search.
  3. Tap Ask AI.
  4. Type your question to have Superhuman AI do the searching for you.
💡 Tip: Ask AI can do more than just search! It can also draft messages for you, create events, analyze emails, answer product questions, and combine information from your inbox and the web. To take full advantage of Ask AI and other Superhuman AI features, upgrade to our Business or Enterprise plan.
You’re on a roll! And one article away from mastering Superhuman Mail on Mobile 🥳
Lastly, we’ll dive into the calendar essentials in Mail 👇
