Dates, Deadlines, Done
From your next meeting to the errands waiting after work, you can zero in on today’s plans without switching apps. Superhuman Mail’s Calendar lets you see and manage your schedule right from your inbox, keeping you focused and prepared while on the move 🚌
See Your Day
Tap the calendar icon in the top left corner. Or, from the main inbox, pull down then swipe right (like you're making an L) for Superhuman Command, and type Open Calendar.
Note that the week view is not yet available.
Adding Calendars
To view all your added calendars or add more (iOS only), pull down then swipe right (like you're making an L) for Superhuman Command, and type Calendar Settings.
💡 Tip: Add the iOS Calendar widget!
Create Events
With Ask AI, you can schedule events right from your phone!
⚡ Try It Now (optional)
  1. You must first be on the Business or Enterprise Plan.
  2. Tap the ai icon in the top left corner of the screen.
  3. Type your scheduling prompt, then tap the purple circle with the arrow.
You can also create an event entirely from scratch.
⚡ Try It Now on iOS
  1. Tap the calendar icon in the top left corner to open your calendar and create an event.
  2. Or, pull down then swipe right (like you're making an L) for Superhuman Command, and type Create Empty Event.
💡 Tip: To make edits to an event, tap on the event then tap the pencil icon in the bottom right corner.
Congratulations!
🎉 You’ve completed the On the Go with Superhuman Mail guide and are ready to fly through your inbox faster than ever!
