Manage your Superhuman Docs account settings
Access your Superhuman Docs account settings, make updates to your preferences, and more.
Your Superhuman Docs account (formerly, "Coda" account) is the individual account that you use to sign in and access Superhuman Docs. Each Docs account is associated with a single user and a single email address. And you can use one account to access multiple workspaces.
Your Superhuman Docs account settings house all of your account-specific information. This includes your email address, your notification preferences, your API settings, and more. Continue reading to learn all about account settings, including what info you can find and what actions you can take.
Access your account settings
You can access your Superhuman Docs account settings in one of two ways:
  1. While logged into Docs, click on your avatar and name in the lower-left corner of any page or doc, then select Account settings from the menu.
    Tip: If you're in a doc and the page list is hidden, you just need to hover over the left edge of the doc to reveal the page list and your avatar.
That’s it - you are now in your Docs account settings. Take a look around!
Contents of account settings
Your account settings contain lots of information and options, split into sections. We’ll cover those sections - including some of the modifications you can make in each - below.
ℹ️ Note that if you are a user on an Enterprise plan, some account settings may be managed by your organization admin.
Profile picture, name, and email
At the top of your account settings, you’ll see your profile image, name, and email address.
  • Profile image: To learn about your profile picture - including how to update it - check out this article.
  • Account name: As of July 2026, the ability to change your account name has been temporarily paused as we work on creating a unified identity system for the Superhuman platform. We apologize for any inconvenience, and we will update this article with instructions as soon as this option is restored.
  • Email address: There isn’t any way to directly change the email address associated with your Superhuman Docs account, but in some cases if you use a third-party identity provider (e.g. Google) Docs will sync email changes as long as the same third-party account is used to log in. As an alternative workaround, you can create a new Docs account with your new email, and invite this new account to your current workspace(s). Then you can transfer ownership of your docs from your old account to your new one.
Security settings
Here you will see security info related to your account, including password information (if you use email/password as your login method).
Publishing preferences
This section contains advanced settings related to publishing, including the option to enable Google Analytics pixel to track page views for your published docs (learn more about this here).
New document defaults
Set defaults for newly created docs, including page width, time zone, and first day of week. These preferences will apply to all docs you create going forward.
Billing info
This section shows all workspaces that your account is a member of, along with the tier of each workspace. If you’re a workspace admin, you’ll also have quick links to your workspace settings.
Email settings and preferences
Use this section to enable or unsubscribe from various types of emails and notifications, depending on your preferences. Learn more about email preferences here.
API settings
Here you can create a new API token and see a list of all existing API tokens associated with your account. Learn more about Superhuman Docs API here.
Accounts connected to Packs
This section contains a full list of all Pack accounts that have been connected via this Docs account. You can even disconnect Pack accounts directly from this section.
Other integrations
See and manage any other integrations that might be connected to this Docs account, including Superhuman Docs for Slack.
Cookie settings
Here you can opt in or out of advertising and third-party publisher cookies. Learn more within your account settings.
Advanced settings
In the Advanced settings section, you’ll see two available actions:
How can I delete my Superhuman Docs account?
Learn all about deleting your Docs account in this article.
Can I change the email address associated with my Superhuman Docs account?
It isn’t possible to directly change the email address of an existing Superhuman Docs account. As a workaround, you can create a new Docs account with the new email address. Then invite this new account to your Docs workspace(s). Finally, transfer ownership of your docs to this new account. If needed, you can then delete the original Docs account.
How do I create an API token?
To create an API token, follow the steps below:
  1. Go to docs.superhuman.com/account
  2. Scroll down to the API settings section
  3. Click the Generate API token button
  4. Give your token a name
  5. Choose a permission level: Read only (the default), Write only, or Read and write. Your choice applies to every resource you select below.
  6. Choose what your token can access. All content is selected by default. This will grant access to all docs and their content.
    1. You can narrow the accessible content by choosing Selected content. Then select up to 10 docs or tables.
    2. Add other resources, such as Packs, the Docs MCP, or your organization (Enterprise org admins only)
  7. Click Generate API token to confirm
  8. Your new token will appear at the top of the list. Click the Copy token button to copy and use.
Learn all about API tokens, including how to create and regenerate them, in this article.
