No matter how busy our days get, the easier it is to set up time, the more time we save. With AI-powered event creation and instant scheduling, you can go from idea to calendar event in seconds.
Superhuman AI
Schedule an event in seconds with Ask AI — it instantly finds a time that works for you and your team!
⚡Try It Now on Desktop (optional)
- You must be on the Business or Enterprise plan. To upgrade your plan, visit superhuman.com/admin.
- Hit Cmd+K (Mac) or Ctrl+K (Windows) → Ask AI or ?
- Prompt Ask AI to create an event for you by including important details like time, invitees, and location
- Click Edit to modify the draft event.
- Hit Save to invite others, and add the event to your calendar.
⚡Try It Now on Mobile (optional)
- From the top of your inbox, pull down then swipe right (like you’re making an L) for Superhuman Command.
- Type Ask AI.
💡 Tip: You can personalize how Superhuman AI creates events.
Create Event
Superhuman AI can also create events for you automatically from any open message.
- In an open message, hit Cmd+K or Ctrl+K → Create Event or B.
- Superhuman AI will automatically include recipients from the thread, a summary of the meeting’s purpose, default Meeting Link Settings, and suggest the best time based on your availability and that of your team.
💡 Tip: You can also create an event manually by hitting Cmd+K or Ctrl+K → Create Empty Event.
⚡Try It Now on iOS:
- In an open message, pull down from the top of the inbox, then type Create Event.
- Or, tap Create event if the suggestion appears at the bottom of the message.
You're making great progress, and have officially reached the halfway mark! 🏁
Next, you'll learn how Mail makes finding time across multiple calendars easier than ever before.
