Compose Quickly
Turn ideas into polished messages in seconds. Superhuman AI helps you draft clear, compelling emails that sound like you without the extra effort.
Write with AI
⚡Try It Now on Desktop
When drafting a message, hit Cmd+J (Mac) or Ctrl+J (Windows) to write with AI. Then, type a prompt and hit Enter to have Superhuman AI draft a message. The more context and keywords you include, the more specific the drafted message will be.
Write with AI can also edit your work! Just hit Cmd+J or Ctrl+J in the draft, then select one of the suggestions, or use the “Describe how to edit the text” field to add in specific instructions.
You can also personalize how Superhuman AI writes!
⚡Try It Now on Mobile
Tap the ai icon above your keyboard to Write with AI, or tap the voice icon in the triage bar or compose bar to use Write with Voice.
Say what you want the email to convey — no need for perfect sentences. When you stop, Superhuman AI turns your words into a polished draft in your tone in seconds.
💡 Tip: Accepting the draft doesn’t send the message. You’ll always have a chance to review and edit before it goes out!
Instant Reply
Wake up to an inbox where your replies are already written!
Instant Reply in Superhuman Mail is best used when you want to respond quickly and efficiently to emails, especially in these situations:
  • Routine responses: For standard replies like acknowledgments or confirmations.
  • Time-sensitive situations: If you're short on time, Instant Reply helps you maintain prompt communication by offering quick draft options.
  • Overcoming writer's block: If you're unsure how to start a response, the suggested drafts can give you a foundation to customize.
We show three draft replies at the bottom of the latest message in a thread that you have received. You can hit Tab to cycle and preview each response.
To insert the reply, hit Enter (Reply All), R (Reply) or F (Forward), make any edits, then send it right off 🚀
Instant Reply appears similarly on mobile! We show three draft replies at the bottom of the latest message. To insert the reply, tap the response you'd like to use.
After you tap your preferred response, a draft message will appear that you can edit. Once the message is ready, tap the send button.
Great job! Next, you’ll discover how to stay effortlessly on top of conversations with Auto Drafts that ensure every follow-up is stress-free.
