Never let an opportunity slip. Superhuman AI reminds you when to re-engage and crafts timely follow-ups that keep conversations moving forward.
Auto Reminders
Click Settings ⚙️ → Reminders to customize your Auto Reminders.
Set your Default Reminder time to when you’re most likely to be in your inbox and ready to follow up.
Then, select which messages you want Superhuman AI to automatically remind you about if you haven’t received a reply.
  • All messages that need a follow-up — Superhuman AI detects when a follow-up is needed based on your latest outgoing message if no reply has been received.
  • All messages with an external recipient — Every email you send externally, even if a follow-up isn't needed.
  • No messages — Turns off Auto Reminders.
Auto Drafts (Business & Enterprise Plans)
When it’s time for you to follow up, Superhuman Mail can draft AI-powered follow-ups for emails you're waiting on, so it's one less thing on your plate. Just review, tweak if needed, and hit send. It’s like having an assistant prepare the messages for you to keep things moving.
When a Reminder is returned (whether it was set automatically or manually), Auto Drafts will generate a follow-up draft in your voice — ready for you to review and send ⚡
⚡Try It Now on Desktop (optional)
  1. You must first be on the Business or Enterprise plan. To upgrade, visit superhuman.com/admin
  2. To turn on Auto Drafts, click Settings ⚙️ → Auto Drafts
  • Follow-ups — Superhuman AI will automatically draft a follow-up for emails still awaiting replies.
  • Responses —  Superhuman AI will automatically draft a response for messages that need a reply from you.
Note that once Auto Drafts are enabled on Desktop, those settings will carry over to Mobile.
If an Auto Draft feels off, hit Cmd+K (Mac) or Ctrl+K (Windows) → Give Feedback on Auto Draft and select Issues with tone or formality. Your feedback goes straight to our AI team to keep improving the feature.
💡Tip: Discover more ways to stay on top of every conversation in our Never Miss a Follow-Up with Superhuman Mail guide.
Nice work! You've officially reached the halfway mark 🏁
Next, we'll take a look at how to keep your inbox organized at scale using Auto Labels and Custom Split Inboxes built just for you.
Up Next
Sort Smarter
