Theme
Carbon
Prefer a darker interface? Switching is easy in Superhuman Mail!
  1. Hit Cmd+K (Mac) or Ctrl+K (Windows) → Dark Mode to switch to a darker look.
  2. To switch back to light mode, just hit Cmd+K or Ctrl+K → Light.
Mobile
  • Pull down from the top of the inbox, then swipe right — like you're making an "L" —  for Superhuman Command.
  • Type Dark.
    • On iOS, tap Always On.
    • On Android, tap Theme then Carbon
  • To switch back to light mode, type Light.
    • On iOS, tap Always Off
    • On Android, tap Theme then Snow
Match MacOS or Mobile
Prefer Mail to match your system theme? We’ve got you covered.
Hit Cmd+K or Ctrl+K → Match MacOS to follow your Mac’s light or dark mode.
Mobile
  1. Pull down from the top of the inbox, then swipe right — like you're making an "L" —  for Superhuman Command.
  2. Type Match.
    • On iOS, tap Match iOS
    • On Android, tap Theme then System Default
💡 Tip: Use Cmd+K or Ctrl+K to explore other settings and preferences!
