Note: Grammarly is now part of Superhuman, a suite of AI tools that includes Go, Grammarly, Coda, and Mail. If you are a Superhuman user, please check out this article: Problems signing in to Superhuman
I forgot my password
- Enter your email address and click Send me reset instructions.
- Click the link in the password reset email.
- On the page that opens, enter your new password and click Reset password.
You may also find these instructional videos helpful:
Note: If you used Google, Facebook, or Apple as your sign-up method, select the corresponding option at www.grammarly.com/signin or in your preferred Grammarly product. If you prefer to create a separate password for your Grammarly account, you can do so at www.grammarly.com/resetpassword.
I don’t remember my account email address
If you forgot your account email address, try these steps:
- Search every email account you use for emails from Superhuman.
- Try requesting a password reset at www.grammarly.com/resetpassword using each email address you might have used to create your account.
If you have a paid account or still can’t locate the login details, contact Support.
I’ve lost access to my phone
If you’ve lost access to your phone and have two-step verification enabled, use one of the backup codes that were available for download during two-step verification setup.
If you don’t have any of your backup codes, follow these steps to contact Support:
- Enter your username and password as usual.
- On the two-step verification page, click Try Another Way.
- Click Contact Support.
- Enter an optional brief description and click Submit.
