Use Docs AI in Superhuman Docs
Learn how to use Docs AI to create tables & content quickly, generate instant insights, organize your data, and take action at scale.
Docs AI is Superhuman’s AI assistant built directly into your docs. Unlike a traditional AI chatbot, Docs AI can take action inside your doc - drafting content, organizing tables, resolving comments, and more - all from a single chat interface.
Note: As of July 8, Coda AI has been replaced by Docs AI. This isn’t just a rename - Docs AI is a new AI experience built directly into your docs. Where Coda AI could answer questions and generate content inline, Docs AI can take action inside your doc: building tables, drafting and editing content, resolving comments, and more.
Docs AI is currently in beta, with new capabilities being added regularly.
Docs AI capabilities
Docs AI can help with a wide range of tasks across your doc and workspace. Here’s an overview of what it can do today:
Category What Docs AI can do Example prompt
Retrieve & synthesize Find docs or rows by topic, read and summarize pages, run formulas, search the web "Find the Vision & Strategy page and give me the TL;DR"
Write & summarize Draft or edit text, create pages, insert callouts or dividers, rewrite for tone or length, create and update AI blocks "Add a TLDR callout at the top of this page"
Communicate Draft status updates or one-pagers, add/respond to/resolve comments "Draft a 4-bullet Slack update from this week's sprint tasks"
Plan & execute Create tables, add/manage columns (including AI columns), bulk-update rows, create views (kanban, calendar, timeline, form, etc.) "Add a Priority column (Low/Medium/High) to the Sprint Tasks table"
Extract Pull data from unstructured files, including PDFs, PNGs, and JPEGs "Extract the invoice dates from the PDFs in the file column"
Docs AI’s capabilities are always growing. Not sure what it can do? Just ask: “What can you do?”
Note: Enterprise admins can control Docs AI access for their organization. For details, see Manage AI and MCP controls for your Docs org.
Docs AI chat
Docs AI chat is your main interface for working with AI in your doc. You can ask questions, give instructions, and Docs AI will act on your behalf — directly inside your doc.
Open Docs AI chat
Click Open Docs AI (the sparkle icon in the lower-right corner of your doc) to open the Docs AI chat panel.
Docs AI chat panel with three suggested prompts and a message box
Note: Docs AI is now available in the Superhuman Docs mobile app. Open a doc in the app, look for the purple sparkle icon in the lower-right corner, and start chatting. For details, see Use the Superhuman Docs mobile app.
Send a prompt
There are several ways to interact with Docs AI:
  • Suggestions: When you open Docs AI, you’ll see suggested prompts based on your doc’s content. Click any to use it as a starting point. The prompt isn’t sent automatically. It populates in the chat bar so you can review and edit it before sending.
  • Type your own: Type any prompt in the chat input and press Enter to send.
  • Slash command: Type / in the chat input to see quick-start prompt shortcuts.
  • @ mention: Type @ to reference a specific page, table, or row from your doc in your prompt.
  • + button: Use the + button to attach additional context — like a page or a file — to your prompt.
Chat history
Your Docs AI conversations are automatically saved so you can pick up where you left off. Your conversations are only visible to you.
Your chat history is available in the top left of your Docs AI chat panel.
  • If you have a blank chat, you can immediately open the history by clicking the clock icon (Chat history).
  • If you have a chat with messages in it already, you can click the pencil icon (New chat) to start a new chat, and the dropdown next to it to access previous chats.
You can explore your past chats in this doc, or click All docs to explore chats from other docs.
Docs AI chat history panel listing past chats, with This doc and All tabs
Tip: You can also use Docs AI when creating tables. When you add a new table, you’ll see an AI chat box open in the right panel. You can describe the table you want to build, and Docs AI will assist you.
AI column
AI column acts as a task assistant: it creates content, tags data, and assigns metrics at scale. Unlike Docs AI chat, AI column runs automatically on every row in a table as data is added.
Note: You can ask Docs AI, or an AI tool connected through the Docs MCP, to create and update AI columns. Describe the column you want instead of configuring it by hand. For example, ask for a column that categorizes feedback across rows.
If you haven’t connected your AI tool yet, see Connect to the Superhuman Docs MCP.
Create an AI column
  1. Press the Add column button (upper right corner of a table) to add a blank column.
  2. You’ll be prompted to choose the column type. Search for and select AI.
  3. Then choose from the list of options: Summarize, Find action items, Find key insights, or Custom prompt. If you’re not sure, just choose your best guess and you can change it later.
  4. Use the structured column builder to select the inputs. At any point, you can change the AI action with the dropdown.
  5. Add additional instructions. A preview appears for each row, so you can adjust your prompt as needed.
  6. If you want to use more than one input, reference multiple columns, or access the formula builder for your prompt, you’ll need to switch the first dropdown to Custom prompt.
    1. Use the freeform prompt builder to write your own prompt. Then select your desired length, tone, and type.
  7. Once you are happy with your prompt, select Fill column.
Pick column type menu with a search box, opened from the plus button in a table
Tip: Want to use AI to only fill a few cells, rather than all the cells of a column? You can do this without actually changing the column type to AI.
To have AI generate content in just one cell, press the AI button in the desired cell to open up the prompt box. To have AI fill multiple cells, highlight the desired cells and then select the Fill button at the bottom of the table.
Auto-fill rows with AI
AI column can auto-fill rows in your data set, by following the pattern of your existing data. This helps you build out your data much faster.
  1. Select the rows in the column that contain data. Drag down until you’ve selected them all.
  2. Hover over the blue dot that will appear in the bottom right corner, which will say Drag down to auto-fill with AI.
  3. Continue dragging down, until you have covered all of the rows you want filled.
  4. AI will then auto-fill these selected rows.
Tip: You can now use AI columns to extract data from PDFs, PNGs, and JPEGs in file or image columns. For instance, upload invoices to a file column, then prompt an AI column to automatically pull the invoice date from each.
AI block
AI block generates insights like summaries, action items, or key themes, and auto-refreshes as new data is added.
Note: You can ask Docs AI, or an AI tool connected through the Docs MCP, to create and update AI blocks. Describe the block you want instead of configuring it by hand. For example, ask for a block that summarizes a write-up.
Summaries & insights
  1. Type / or Ctrl+Space on a new line in your doc.
  2. From the AI dropdown, select Summarize.
  3. In your prompt, @ reference the table or page with your relevant data.
  4. Choose your desired length, tone, and type. Select Create.
Example prompts for step 3:
  • Summarize [customer feedback page] and group by three key themes.
  • Find two positive quotes from [user feedback table]
  • Highlight three things the marketing team is working on based on [weekly meeting notes page].
To refresh the block, hover over it and click the rounded arrow in the upper-right corner.
Action items
  2. From the AI dropdown, select Find action items from…
  3. @ reference the page or table with your notes.
  4. Choose your desired length, tone, and type (checkboxes recommended). Select Create.
To refresh, hover over the block and click the rounded arrow in the upper-right corner.
Docs AI in text
You can also use Docs AI right within your text.
  1. Highlight any text in the canvas of the doc. The formatting bar appears.
  2. On the right edge of the format bar, click the sparkle AI icon (Ask AI).
  3. Give the AI a prompt for this text.
Highlighted paragraphs in a doc with a Docs AI Rewrite prompt box below the selection
You can ask Docs AI to rewrite, shorten, expand, fix grammar, improve clarity, and more. Beyond basic text editing, you can also ask AI questions about the highlighted text or instruct AI to take action. If you want to elaborate or iterate further, click Open chat to continue the conversation in the side panel.
What will I pay to use Docs AI?
Paid Doc Makers have Docs AI included automatically with generous limits (fair use policies apply, but aren’t designed to restrict normal use). Editors and members of Free workspaces have access to a limited free tier. Once they’ve reached the limits of the trial, they need to upgrade to a paid Doc Maker role to continue having access to Docs AI. Learn more in Docs AI credits & pricing.
Who can use Docs AI?
Docs AI is automatically included in Superhuman docs. Doc Makers on paid tiers (Pro, Team/Business, Enterprise) have full access to Docs AI with generous limits, designed only to prevent abuse, while Editors and members of Free workspaces have access to a free trial. Docs AI capabilities depend on your role in your workspace, so Editors can only take editor-level actions. For details, see Roles in Superhuman Docs: Doc Makers, Admins, and Editors.
Is Doca AI HIPAA compliant?
Yes, Docs AI is HIPAA compliant. Compliance with HIPAA does require disabling certain features, such as web search. But the primary functions of Docs AI will still be available. Learn more in HIPAA compliance information for Superhuman Docs.
Why am I seeing a “something went wrong” error when using Docs AI?
We’re improving the stability of the service to prevent this error in the future. In the meantime, starting a new chat usually resolves the issue.
How does Docs AI use my data?
When you use Docs AI, your content is shared with our third-party AI providers to generate a response. We do not allow third-party providers to use your data to train their models. For more, see coda.io/trust/security and our Privacy Statement.
Which AI credits are used when I manage AI blocks with Docs AI or the Docs MCP?
Docs AI uses the AI credits included in your Doc Maker license. The Docs MCP uses your AI tool’s own tokens.
