For Enterprise only: Learn how about our domain capture feature, including how to add and verify owned domains in your Admin Settings.
Customers on Superhuman Docs' Enterprise plan can utilize domain capture by adding owned domains in their admin settings. Once domains have been added and verified, org admins can manage docs and users with those owned domains. This includes user authentication, provisioning, and more. Read on to learn all about adding and verifying owned domains.
📣 Domain capture is only available to customers on our Enterprise plan. If you're on a non-Enterprise plan and looking to learn about auto-join email domains instead, check out this article. And if you'd like to learn more about upgrading to Enterprise, get started here.
Add new domains
When you first upgrade to the Enterprise plan, at least one domain will automatically be added to your owned domains. Superhuman Docs looks at the email addresses of your workspace members (and doc owners), and pulls all unique email domains. For instance, if you have some workspace members with a @domainA.com email and others with a @domainB.com email, we will automatically add both @domainA.com and @domainB.com to your owned domains. You can see these automatically-added domains by going to your Admin settings, then clicking into the Domain registration tab. Note that you will need to verify these owned domains in order to activate your Enterprise plan. Refer to the section below on domain verification.
If you want to add more domains, in addition to the ones automatically identified, just follow these steps:
  2. Click on your name in the lower-left corner, then choose Admin settings from the list
  3. Click into the Security setup tab (within the Security section)
  4. You'll see some information about the transition from coda.io to docs.superhuman.com. For now, your domain registration is still managed on coda.io. Click Manage security settings, and you will be redirected to a coda.io page.
  5. In the new coda.io page, select the Domain registration tab.
  6. Under the Owned domains section, click the Add domain button
  7. Enter the domain in the appropriate field, then click Add
Now that you’ve added a domain, the next step will be to verify it (see the Verify domains section below for instructions). Note that you won’t be able to start managing users from that domain until you’ve completed the verification process.
Verify domains
To complete the process of adding owned domains, org admins will need to verify each domain. To do so, just follow these steps:
  1. Go to docs.superhuman.com
  2. Click on your name in the lower-left, then select Admin settings from the menu
  3. Select the Security setup tab (within the Security section)
  4. Click Manage security settings, and you will be redirected to a coda.io page.
  6. Under the Owned domains section, click Verify next to the domain you need to verify
  7. A dialog will open, containing instructions on completing the verification process. The instructions are as follows:
    1. Go to your domain host provider and navigate to the DNS section.
    2. Create a new TXT record and name it the domain or subdomain you are pointing to. Then, copy/paste the code above in the relevant field.
    3. Typically this update will only take a few moments to process. However, there are cases where it might take 48 hours for the DNS record to propagate.
    4. Click the Verify button at the bottom of the dialog, and we will check your DNS record.
Why am I being redirected from superhuman.com to coda.io in order to set up domain registration?
Now that Docs is officially a part of Superhuman, our team is working on a unified identity system for the Superhuman suite. But while that work is still in progress, you will continue to manage domain registration, authentication, and provisioning through coda.io.
How do I remove an owned domain?
You can remove an owned domain from the Domain registration tab of your admin settings (via Security setup). Simply click on the three horizontal dots next to the domain, and select the Remove domain option.
Note that if there is currently a member with that domain in your org, you will not be able to delete the domain. You’ll first need to remove that member before you can proceed with removing that domain.
Who has the ability to add, verify, and remove owned domains?
Only org admins on the Superhuman Docs Enterprise plan have the ability to add, verify, or remove owned domains.
Why am I seeing an error that says “Your workspace contains docs or users not associated with a verifiable domain name”?
You’ll see this error message if you try to upgrade to Enterprise but have one or more members in your workspace with non-work email addresses (ex: @hotmail.com, @gmail.com, etc.). Since these domains cannot be owned by your org, these members must be removed and offboarded from your workspace before you can activate your Enterprise org.
How does Superhuman Docs know which domains to automatically add to my “owned domains”?
When you first upgrade to an Enterprise plan, Superhuman Docs will pull all the domains found across your current workspace member list, and will automatically add these to your owned domains. In order to finish activating your Enterprise org, you will need to verify all of those auto-added domains.
Is the owned domains feature the same as the auto-join domains feature?
No - these are separate features. The owned domains feature is an Enterprise-only, org-level feature. It allows org admins to manage users from those domains, as well as manage their docs.
The auto-join domains feature is a workspace-level feature, available on all Superhuman Docs a la carte plans (Free, Pro, Business, and Enterprise). This feature ensures that anyone with a certain email domain is automatically added to your Docs workspace when they sign up. Learn more here.
