Use the Workspace Members section in your Docs admin settings to invite new members, monitor doc and AI activity of existing members, change roles, & more.
Collaboration is one of the strong suits of Superhuman Docs. Not only can you add people to your individual docs, you can also invite them to your Docs workspace. Whether it’s your entire company, your team, or your friends, we recommend adding anyone to your workspace who you’ll be collaborating with regularly in Docs.
On October 29, 2025, Superhuman launched bundled plan offerings for Docs (formerly "Coda"), Grammarly, and Superhuman Mail. If your Docs workspace is connected to a Superhuman bundled plan, some of the instructions in the following article will not apply. Instead, inviting and managing members will be handled through the Superhuman Admin Hub. Please head to this article for information on managing your workspace members through the admin hub.
Invite people to your workspace
If you are a workspace admin, you have the ability to invite people to your workspace. When you add people to a workspace, they become members. You decide what they can and can't do based on their role (see Roles in Superhuman Docs: Doc Makers, Admins, and Editors for more info).
To add someone to a workspace, first navigate to docs.superhuman.com, then locate the workspace name in the left panel. Click on the three-dot menu to the right of this workspace name, and select the Members & Groups option. Look for the Invite button in the upper-right corner. Note that you will only see this button if you are a workspace admin.
📣 If your Docs workspace was created through or is bundled with Superhuman, you'll be redirected to the Superhuman admin hub to complete the process of inviting members. You can therefore skip the rest of the instructions in this section.
You can then enter their emails or names to search your contacts. Once you’ve selected the invitee, choose which role this new member should have. If you want them to be able to create and build new docs and pages, you can make them a Doc Maker. If you just want them to be able to view and edit existing docs or pages, make them an editor.
Before you invite them, choose whether to notify them of the invite. If you do opt to notify them, you can enter a brief message for them into the field below.
Once that’s all done, just hit Invite. This will instantly add them to your workspace. Hooray!
Set up auto-join email domains
The auto-join email domains feature ensures that members of your team are seamlessly added to the correct Docs workspace. When anyone with an email address from one of your auto-join domains joins Superhuman Docs, they will automatically be added to your workspace (as an editor).
Please note that the auto-join email domain feature is not currently available for Docs workspaces that are part of a Superhuman bundle. Instead, Superhuman orgs utilize a similar feature called prompt to join. Learn more here.
To add a new auto-join domain, simply follow these steps:
  1. From docs.superhuman.com, locate the workspace name in the left panel, click on the down arrow next to this name, then select Admin settings from the options
    1. Tip: If you are a member of multiple workspaces, you'll click on the three-dot menu next to the workspace name instead.
  2. Click into the Membership policies tab (under the Workspace members section)
  3. Locate the Auto-join email domains section, and click on the + Add domain button
  4. Choose which domain you want to add from the dropdown
  5. Click the Add button to confirm
Note that you will only see domains that are currently represented by the admins in your workspace. To add another domain, promote someone from that domain to be a workspace admin and ask them to complete the above process. Or, if your workspace has a parent organization, an org admin will need to register the domain to the organization first.
To remove an auto-join domain, simply hover next to the domain and click on the trash icon that appears to the right of the domain name.
Manage existing members
For all Docs workspaces, you can view a full list of workspace members in the Members & groups section, within the three-dot menu next to the workspace name. Here you can search for members and see their roles. Any member of the workspace can access this panel.
If your Docs workspace= is linked to a Superhuman bundle, all member management - including inviting members and changing their roles - will instead be handled in the Superhuman admin hub.
For workspace admins in paid workspaces (Pro, Team, and Enterprise), you can do even more in the Workspace members section within the Admin settings. Here you can:
  • search for specific workspace members (including current, removed, and offboarded)
  • assess member activity (including high-level doc and page activity and AI credit usage per member)
  • change member roles
  • view and approve Doc Maker requests
  • copy email addresses
To find this Workspace members section, just go to docs.superhuman.com, click on your name in the lower-left corner, then select Admin settings from the menu. Then click into one of the tabs within the Workspace members section.
Note that only Enterprise workspaces will include the Total collaborators column in their Members tab.
Search for workspace members
In the Members and roles page of admin settings, you can use the built-in filters to search for specific workspace members. You can filter for current, removed, or offboarded members. You can also search the list of members by name and email using the search bar. When you select multiple members using the checkboxes on the left, you will be able to edit and export the selected list of users.
Assess member activity
As a workspace admin, it’s likely important for you to be able to monitor the high-level activity and usage of your workspace members. This can be especially helpful when deciding which of your members should be editors and which should be Doc Makers.
Under the Members and roles tab of the admin settings, you’ll see the following useful columns for each member:
  • Docs last active: the last time anyone visited a doc that this member owns or contributes to
  • Total docs: the number of docs that this member owns, manages, or to which they have added pages, in the last 90 days
  • AI usage: the amount of AI credits used by this member in the last 90 days. If you want to learn more about AI credits and managing AI usage, check out this article.
💡Tip: You can use the columns above to understand which editors might be ready to become Doc Makers.
Change member roles
You can also change the role of a workspace member within the Members and roles tab of admin settings. Just find the member whose role you want to change. Then, under the Workspace role column, click on their current role to open a drop-down of role options. Choose their new role from these options.
View and approve Doc Makers
If a member in your workspace has requested to become a Doc Maker, you will see a Pending requests section on the Members and roles page. Click Approve to upgrade this member to a Doc Maker, or click Details to learn more or deny the request. Learn to customize how your workspace members become Doc Makers by checking out this article.
Note that only existing workspace members can request to become Doc Makers. Non-workspace members will have to contact an admin and be manually added to the workspace as a Doc Maker.
Copy email addresses
If you need to copy the email addresses of multiple workspace members at once, you can do so via the Members and roles tab. Just check the box to the left of all the members in question, then click the Copy emails button above the members list. The emails will be copied to your clipboard.
Export member list
Workspace admins can also export a list of workspace members in the form of a CSV file. This makes it easier to analyze workspace membership patterns, including who has joined and any recent upgrades. To export the member list, follow these steps:
  1. Navigate to the Members and roles page within the admin settings
  2. At the upper-right of your member list, you'll see an Export button. Click this button, then click Generate export to confirm.
  3. Once the file has been generated, you will receive an email with a link to download the .csv file. Please keep in mind that this link is only valid for 1 day.
📣 Looking for even more granular controls and more management options? The Docs Enterprise plan may have what you need. Learn all about Enterprise security and controls in this article. And if you're ready to upgrade, you can get started here.
How can I remove someone from my workspace?
If you’re a workspace admin wanting to remove someone from a specific workspace and reassign doc ownership, check out this article. If you’re an Enterprise org admin wanting to deactivate a members from all managed workspaces, head this way.
What’s a workspace admin?
A workspace admin is a specific type of Doc Maker in Superhuman Docs. This role comes with elevated permissions that allow admins to adjust settings and make changes for the entire workspace. You can read more about the role here.
How can I control the addition of new Doc Makers in my workspace?
Check out this article to learn all about Doc Maker management and approval controls.
How do I decide which members should be Doc Makers and which should be editors?
Doc Makers have the ability to create and manage docs and pages and use Docs AI, while editors can contribute to existing docs and pages. If you’re a workspace admin, you can use various columns in the Members and roles tab of your admin settings to determine which current editors might be ready to move into a Doc Maker role. Check out the section above to learn more.
Why do I see someone in my workspace that is no longer with the company?
If there is a doc in your workspace that has an owner that is no longer in the company, you may see their name appear in the workspace membership list. If you remove this person, then their docs become read only until ownership of the doc is changed. Learn about how to transfer docs here.
How can I get access to even more membership management tools?
The Docs Enterprise plan offers the highest level of member management, including authentication, provisioning, and much more. If you're interested in upgrading, you can get started here.
What happens if I have auto-join already enabled for my workspace and we upgrade to a Superhuman bundle?
At this time, the auto-join email domain feature described in this article is not supported for workspaces that are part of a Superhuman bundle. However, the Superhuman bundle does have a similar feature called prompt to join. If you are already using auto-join and then upgrade your workspace to the Superhuman bundle, your auto-join will be disabled and prompt to join will be automatically enabled.
