Dates, Deadlines, Done
From your next meeting to the errands waiting after work, you can zero in on today’s plans without switching apps. Superhuman Mail’s Calendar lets you see and manage your schedule right from your inbox, keeping you focused and prepared while on the move 🚌
See Your Day
Tap the Calendar icon in the navigation bar.
💡Tip: Learn how to switch between multi-day views on iOS.
Add Calendars
To view all your added calendars or add more (iOS only), pull down then swipe right (like you're making an L) for Superhuman Command, and type Calendar Settings.
💡 Tip: Add the iOS Calendar widget.
Create Events
Ask AI to schedule events for you!
⚡ Try It Now (optional)
  1. You must first be on the Business or Enterprise Plan.
  2. Tap the AI icon (sparkles) in the top-right corner of the main inbox.
  3. Type your scheduling prompt, then tap the purple circle with the arrow.
You can also create an event entirely from scratch.
⚡ Try It Now
  1. Tap the Calendar icon in the navigation bar to open your calendar.
  2. Tap a time on your calendar.
  3. Fill in the details, then tap the checkmark to create the event.
💡 Tip: To make edits to an event, tap on the event, then tap the pencil icon in the bottom right corner.
Congratulations!
🎉 You’ve completed the On the Go with Superhuman Mail guide and are ready to fly through your inbox faster than ever!
