You can easily manage your calendar without leaving your inbox π
See your Day & Week
Hit Cmd+K (Mac) or Ctrl+K (Windows) βΒ Open Day or 0 (zero) to see today's schedule in the right sidebar.
When you open or hover over a calendar invite, you'll see your schedule for that day appear in the sidebar.
To see your week, hitΒ 2Β or Cmd+KΒ orΒ Ctrl+KΒ βΒ Open Week.Β
Hit = or J to advance to the next week, and - or K to return to the previous week. Hit T to return to today.
MobileΒ
To see your day, tap the Calendar icon in the top left corner.Β
You can also pull down from the top of the inbox, then swipe right to open Superhuman Command β like you're making an "L" β and tap Open Calendar to see your day.
If a message includes a date, tap the button that appears below the message to see the mentioned day.Β
Or, when viewing a calendar invite, tap the calendar iconΒ next to the date.Β
iOS only
To see your month, tap the month name in the top-left corner, or tap the dropdown arrow beside it to expand the calendar.
Swipe within the month to move month-to-month, then tap Today to return to the current date.
To switch between multi-day views, tap the view selector icon in the top-right corner.
The month view and multi-day views are not yet available on Android.
The week view is not yet available on Mobile.Β
Adding Calendars
Hit 2Β or Cmd+K or Ctrl+KΒ βΒ Open Week.Β Click β next to Calendars to sign in with Google or Microsoft.Β
You can also hit Cmd+K or Ctrl+K β Calendar SettingsΒ and clickΒ Sign in with GoogleΒ orΒ Sign in with Microsoft.Β
To change the calendar color, click ... to the right of eachΒ calendar.
To turn on calendar notifications, hit Cmd+KΒ orΒ Ctrl+KΒ βΒ Event Notifications andΒ select your preferred time.Β
Mobile (iOS only)
To add your other Gmail or Microsoft calendars:
- Pull down from the top of the inbox, thenΒ swipe rightΒ to open Superhuman Command β like you're making an "L."
- Type Calendar Settings.
- Tap on the circle to enable or disable your specific calendars, or tapΒ Sign in with Google or with Microsoft to add calendars from other accounts.
Adding TimezonesΒ
DesktopΒ
You can add another timezone to your calendar by hitting Cmd+K or Ctrl+K β Timezone Settings.Β
The secondary timezone will appear in the week view.
Mobile
Adding a secondary timezone is only available on Desktop at the moment.
Share AvailabilityΒ
Learn how to quickly share your availability with others.Β
Create Event and Find Time
Learn how to create events and find the best time to meet with teammates!Β
Is there a week view?
Not yet. The new view selector gives you 1-day, 2-day, and 3-day options.
Is there a full month view?
There isn't a dedicated month view, but you can tap the month name (or the dropdown arrow next to it) to expand a full-month sheet and tap any date to jump there. It's designed for quick navigation rather than a persistent view.
