Imagine your inbox is overflowing, but you need to zero in on the most important messages. Sorting through everything manually slows you down. Auto Labels cut through the noise and highlight what matters, so you can focus and reply to the important ones first.
Auto Label Library
Explore premade Auto Labels in the Auto Label Library.
⚡ Try It Now
  1. Click Settings ⚙️ → Auto Label Library. Or, from the top of your inbox on Mobile, pull down then swipe right (like you’re making an L) for Superhuman Command, and type Auto Label Library.
  2. Select the Auto Labels you'd like to enable.
  3. Going forward, new emails, as well as the last 14 days of emails, that match the definition will be automatically labeled.
To view the conversations with a given label, hit Cmd+K (Mac) or Ctrl+K (Windows) → go to [label]. Or, hit the Left arrow key while in your inbox to view your labels. On Mobile, tap Important or Inbox to view your labels.
Custom Auto Labels (Business & Enterprise plans)
Customize your inbox even further by creating your own Auto Labels using AI and deterministic criteria.
⚡ Try It Now on Desktop (optional)
  1. You must first be on the Business or Enterprise plan. To upgrade your plan, visit superhuman.com/admin.
  2. Hit Cmd+K or Ctrl+K → New Auto Label.
  3. Click Build Your Own.
  4. Define your custom Auto Label.
    • Decide whether you want to start with deterministic criteria (From, To, Subject, etc.) or an AI prompt.
    • Combine multiple criteria using AND (for all criteria) or OR (for any criteria).
    • Click Add exclusions to set criteria for emails that should not receive the label.
  5. A preview section will appear on the right, analyzing conversations in real time and pulling results that match your current prompt.
    • Click ✔️ or ✖️ next to a result to fine-tune the Auto Label.
  6. Click Create to finalize your custom Auto Label.
Edit Auto Labels
On Desktop, click Settings ⚙️ → Auto Labels, then click ⚙️ beside the Auto Label. Editing custom Auto Labels on Mobile is not yet available.
Great work! Next, you’ll learn how to apply your Auto Labels to add structure to your inbox with Split Inbox.
