As you learned in our Get Started course, Split Inbox organizes your email into separate sections that help reduce distractions and increase efficiency. In addition to the many options in our Split Inbox Library, you can tailor your inbox to your needs by creating your own Split Inbox.
You can define a Split Inbox using most search criteria (From:, To:, Subject:, Bcc:, Cc:). And combine multiple criteria using “OR” and “AND”.
You can even define a Split Inbox using Auto Labels to give them the power of Superhuman AI.
⚡ Try It Now on Desktop
- Click Settings ⚙️ → Split Inbox Library.
- Click Build Your Own.
- Give your new Split Inbox a name.
- Enter a definition like, “from: my_boss@email.com” or “subject:lead".
- Select a favorite Auto Label.
- Click Create and enjoy the more focused view!
Remember, Split Inboxes are meant to promote focus. You should use them for noisy emails you want to cordon off and important emails you want to prioritize. Three to seven tends to be the right number of Split Inboxes to provide structure and prioritization. Too many can be distracting and actually slow you down!
Editing a Split Inbox
You can easily add more email addresses to existing Split Inboxes to support your organizational structure. Just select the email you’d like to add to a Split Inbox and hit Cmd+K (Mac) or Ctrl+K (Windows) → Add to Split Inbox.
For more advanced edits to your Split Inboxes — like reordering or hiding empty ones — click Settings ⚙️ → Split Inbox.
💡 Tip: Name your Split Inboxes with an emoji to save space and add color! Hit : then type the emoji name 📈
Next, you’ll learn how to avoid the clutter before it arrives with Auto Archive & Unsubscribe.
Up Next
