Auto Reminders & Auto Drafts
Auto Reminders
Superhuman Mail will automatically remind you about emails that haven’t received a reply.
  1. Click Settings ⚙️ → Reminders to customize your Auto Reminders.
  2. Set your Default Reminder time.
  3. Then, select which messages you want Mail to automatically remind you about if you haven’t received a reply.
  • All messages that need a follow-up — Superhuman AI detects when a follow-up is needed based on your latest outgoing message if no reply has been received.
  • All messages with an external recipient — Every email you send externally, even if a follow-up isn't needed.
  • No messages — Turns off Auto Reminders.
You can also choose whether to apply Auto Reminders to Weekdays Only
Mobile
  1. Pull down from the top of the inbox, then swipe right — like you're making an "L" — for Superhuman Command.
  2. Type Customize Reminders.
  3. Set your Default Reminder time, then select which messages you want an automatic reminder for if you haven't received a reply.
You can select whether to apply Auto Reminders to Weekdays Only
Auto Drafts (Business & Enterprise Plans)
Mail can draft AI-powered follow-ups in your voice  — ready for you to review and send ⚡
When a Reminder is returned (whether it was set automatically or manually), Superhuman AI will automatically draft a follow-up for emails that are still awaiting replies, or when someone asks to meet with you.
  1. Click Settings ⚙️ → Auto Drafts
  • Follow-ups — Superhuman AI will automatically draft a follow-up for emails still awaiting replies.
  • Scheduling — Superhuman AI will automatically draft a reply when someone asks to meet.
    • To loop in a teammate for scheduling, check the box beside Add teammate on Cc to handle scheduling. Type their name in the “teammate” line, then type your AI prompt.
2. Once you’ve made your selections, your Auto Draft settings will save automatically.
Note that once Auto Drafts are enabled on Desktop, those settings will carry over to Mobile.
Mobile
  1. Pull down from the top of the inbox, then swipe right — like you're making an "L” — for Superhuman Command.
  3. Toggle on Auto Drafts for Follow-ups or Scheduling.
Note that your drafts from Gmail and Outlook will sync with Mail.
💡 Tip: Use Write with AI to make edits to an Auto Draft.
The Auto Drafts don't sound like me.
When you first enable Superhuman AI, we analyze a sample of your recent emails to get a sense of your tone and writing style.
If this doesn't feel quite right, please hit Cmd+K (Mac) or Ctrl+K (Windows) → Give Feedback on Auto Draft to select the Issues with tone or formality box.
That'll send the feedback directly to our AI team about the Auto Draft so we can continue improving the features.
How do I discard an Auto Draft draft?
Hit Cmd+K or Ctrl+K → Discard Draft or Cmd+Shift+, or Ctrl+Shift+,.
What happens if I mark a message Done with an Auto Draft?
This does not automatically discard the Auto Draft. The conversation will appear in your Done folder with the Auto Draft, or your Drafts folder when you hit G then D.
When is an Auto Draft added to a conversation?
An Auto Draft is added to a conversation with a Reminder (Auto or manual) about an hour before the Reminder is set to return.
