Print
You can quickly print an email in Superhuman Mail 🖨️ ✨
  1. Open the thread you would like to print.
  2. To expand all messages in a thread, hit Shift+O.
  3. Hit Cmd+P (Mac) or Ctrl+P (Windows).
  4. Click Print.
Mobile (iOS only)
  1. Tap on the thread you would like to print.
  2. To print just a specific message, swipe left on the message and tap Expand.
  3. Pull down from the top of your inbox to open Superhuman Command.
  4. Type Print.
How do I print a single email on Desktop?
There isn’t a way to print a single email in a thread on Desktop, however we recommend the following workaround for the time being:
  2. Hit Shift+O twice to collapse all messages in the thread.
  3. Then use N and P to navigate to the message you want to print.
  4. Hit O to expand that message, then hit Cmd+P or Ctrl+P to print with just that message open.
How do I save an email as a PDF?
Mac
  1. Hit Cmd+P.
  2. Select Save as PDF from the dropdown in the bottom left corner.
  3. Click Print.
Windows
  1. Hit Ctrl+P.
  2. Under Select Printer, select Microsoft Print to PDF.
  3. Click Print.
