Auto Reminders & Auto Drafts
Auto Reminders
Superhuman Mail will automatically remind you about emails that haven’t received a reply.
  1. Click Settings ⚙️ → Reminders to customize your Auto Reminders.
  2. Set your Default Reminder time.
  3. Then, select which messages you want Mail to automatically remind you about if you haven’t received a reply.
  • All messages that need a follow-up — Superhuman AI detects when a follow-up is needed based on your latest outgoing message if no reply has been received.
  • All messages with an external recipient — Every email you send externally, even if a follow-up isn't needed.
  • No messages — Turns off Auto Reminders.
You can also choose whether to apply Auto Reminders to Weekdays Only
Mobile
  1. Pull down from the top of the inbox, then swipe right — like you're making an "L" — for Superhuman Command.
  2. Type Customize Reminders.
  3. Set your Default Reminder time, then select which messages you want an automatic reminder for if you haven't received a reply.
You can select whether to apply Auto Reminders to Weekdays Only
Auto Drafts (Business & Enterprise Plans)
Open your inbox to find every reply already drafted for you — written in your voice and tailored to each thread — so you can respond to what matters most in a fraction of the time.
Auto Drafts writes two types of replies automatically:
  • Follow-ups — Superhuman AI will automatically draft a follow-up for emails still awaiting replies.
  • Responses —  Superhuman AI will automatically draft a response for messages that need a reply from you.
  1. Click Settings ⚙️ → Auto Drafts
  2. Toggle on the types of Auto Drafts you want.
  1. Your settings save automatically on Desktop, and carry over to Mobile.
Note that for now, enabling Auto Drafts for Responses will turn off Instant Reply.
💡 Tip: Use Write with AI to make edits to an Auto Draft, or fine-tune your style by clicking ⚙️ Settings → Personalization.
Mobile
  1. Pull down from the top of your inbox, then swipe right — like you’re making an “L” — for Superhuman Command.
  2. Type Auto Drafts Settings.
  3. Tap the account of your choice.
  4. Toggle on Auto Drafts for Follow-ups or Responses.
Note that your drafts from Gmail and Outlook will sync with Mail.
How Auto Drafts work
Multiple versions
When more than one response makes sense, you’ll see chips at the top of the draft — click a chip to switch between versions.
Placeholders
When Superhuman AI can’t infer something — like a specific date or name — it leaves a placeholder for you to fill in. If a placeholder is still present when you hit send, Mail will alert you before the email goes out.
Stays fresh
Once a day, Mail checks your Auto Drafts and updates them if something has changed — like a time reference or new context from your inbox.
Editing
If you edit an Auto Draft, it becomes a regular draft and won’t be automatically updated.
Personalization
You can further personalize Auto Drafts on Desktop.
  • To set preferences for writing and scheduling, click Settings → Personalization. You can specify preferences like"avoid scheduling on Wednesdays", "always use lowercase", or "always use this booking link for intro calls."
  • To add files and links that Auto Drafts can refer to, click Settings → Knowledge Base. You can even share this knowledge across your team, so everyone can move faster with messaging and answers that are grounded, accurate, and up to date.
Once you personalize your settings on Desktop, they’ll automatically sync to Mobile.
💡 Tip: Learn more about Personalization here
The Auto Drafts don't sound like me.
When you first enable Superhuman AI, we analyze a sample of your recent emails to get a sense of your tone and writing style. To fine-tune your style, click ⚙️ Settings → Personalization.
If the Auto Drafts aren’t quite hitting the mark after personalizing your AI settings, please hit Cmd+K or Ctrl+K → Give Feedback on Auto Draft to select the Issues with tone or formality box.
That'll send the feedback directly to our AI team about the Auto Draft so we can continue improving the features.
How do I discard an Auto Draft draft?
Hit Cmd+K or Ctrl+K → Discard Draft or Cmd+Shift+, or Ctrl+Shift+,.
What happens if I mark a message Done with an Auto Draft?
This does not automatically discard the Auto Draft. The conversation will appear in your Done folder with the Auto Draft, or your Drafts folder when you hit G then D.
When is an Auto Draft added to a conversation?
Superhuman AI adds Auto Drafts in three situations:
  • Follow-ups —  When a conversation has a Reminder set — auto or manual — Superhuman AI adds a follow-up draft about an hour before the Reminder is set to return.
  • Responses —  When an email that needs a reply arrives in your inbox, Superhuman AI drafts a response right away so you can send with one click — or edit and send.
  • Scheduling — When an email requires finding time with someone, Superhuman AI drafts a reply with your available times as soon as the email arrives.
How does Superhuman AI know which messages need a reply?
Superhuman AI looks at your inbox and automatically identifies emails that need a response — no setup required. If you have the Respond Auto Label enabled, those messages will also receive an Auto Draft so your reply is ready to go. But Auto Drafts for responses work whether or not you use that label.
