Gmail accounts
Adding an Alias
You can set up new aliases in Gmail settings.
- Hit Cmd+K (Mac) or Ctrl+K (Windows) → open Alias Settings.
- Then under Send mail as, click Add another email address.
- Once you've added the email address, return to Superhuman and hit Cmd+R or Ctrl+R to refresh.
Mobile
Alias settings are only accessible via Desktop at the moment.
Sending from an Alias
Hit Cmd+K or Ctrl+K → Change Alias or Cmd+Shift+F or Ctrl+Shift+F while composing an email.
Then, select an address from the list that appears.
Mobile
When replying to an existing conversation, expand your draft to full screen by tapping here:
Tap on this arrow:
Then, tap the From: address and select an address from the list that appears.
Setting a Default Alias
If you'd like to always use a certain alias to send emails, you can set that up in Gmail.
- Hit Cmd+K or Ctrl+K → Alias Settings.
- Click make default next to your alias.
- Select Always reply from default address.
Once you've made those changes, return to Superhuman Mail and hit Cmd+K or Ctrl+K → Sign Out to log out and back in, syncing your changes.
Outlook accounts
Superhuman Mail will respect the primary alias set in your Outlook settings, but there isn’t a way to switch between aliases in Superhuman Mail with an Outlook account.
- In Outlook, click Add an alias.
- Create a new Outlook email address or add an existing email address as an alias.
- Once you’ve made your selection, click Add alias.
- Return to Superhuman Mail, and hit Cmd+R or Ctrl+R to refresh.
Mobile
Alias settings are only accessible on Desktop at the moment.
