Muting Conversations
Some email conversations get noisy, which can lead to distractions. But you still need to receive updates or refer to the email chain later. In these cases, hitting unsubscribe or marking spam is not an option. Luckily, Superhuman Mail allows you to mute conversations.
Gmail accounts
To mute a conversation, hit Cmd+K (Mac) or Ctrl+K (Windows) Mute or Shift+M on a message.
Muted conversations will leave your inbox and move to the Mute folder. To access this folder, hit Cmd+K or Ctrl+K → go to Muted or G then M.
If you need to unmute a conversation, just hit Cmd+K or Ctrl+KUnmute or Shift+M again.
Mobile
To mute a conversation on Mobile:
  1. Tap the message you want to Mute.
  2. Pull down from the top of the inbox for Superhuman Command.
  3. Type then tap Mute
This will mute the conversation and send it to the Mute folder.
To access this folder, pull down from the top of the inbox then swipe right — like you're making an "L" —  and type go to Muted
To unmute a conversation:
  1. Tap the message you want to Unmute.
  3. Type then tap Unmute
Outlook accounts
There isn't a way to mute threads on Outlook accounts on Desktop or Mobile, but we hope to include this feature in the future 💫
