Remove Superhuman
One day we may have to part ways, and that’s okay!
Native Mac App
  1. Open your Mac's Applications folder.
  2. Drag Superhuman to your Mac's Trash.
Native Windows App
  1. Select Start  > All apps and search for Superhuman in the list shown.
  2. Press-and-hold or right-click on Superhuman.
  3. Select Uninstall.
Chrome Extension
  1. In Chrome, go to chrome://extensions
  2. Click Remove for Superhuman.
How to revoke Superhuman’s access to your Gmail account
  1. Open your Google account permissions.
  2. Click Superhuman.
  3. Click Remove.
How to revoke Superhuman’s access to your Outlook account
  1. Open account.microsoft.com/account and sign in to your account.
  2. Click on the Privacy tab at the top of the page. You may need to verify your identity via an email code.
  3. Scroll down to the Other privacy settings section.
  4. Go to Apps and services > Apps and services that can access your data.
  5. Review the list of apps and establish which you want to revoke.
  6. Find Superhuman and click on Edit to adjust those settings.
How to remove Superhuman as your default email reader on Mac
  1. Open your Mac's built-in Mail app.
  2. Click Mail → Preferences in your Mac's menu bar.
  3. Under Default email reader, select Google Chrome.
