SAML Authentication
Overview
Superhuman Mail supports single sign-on (SSO) using any SAML-based Identity Provider (IdP).
Note: Superhuman Mail also supports SSO for Google and Microsoft Accounts.
Configuring SAML
Warning: Modifying SAML/SSO settings may impact users' access to Superhuman Mail. If you have any questions or need support, please reach out to hello@superhuman.com.
Prerequisites
  • You will need administrator access to your organization’s Identity Provider.
  • Your team must be on a Superhuman Mail Enterprise plan.
Configuration Steps
Reach out to your Account Manager or hello@superhuman.com to get the setup process started.
Step 1. Check your inbox for an email with the subject Set up SSO and Directory Sync and click the button:
Step 2. Select the option to Configure Single Sign-On:
Step 3. Select your organization's Identity Provider:
Step 4. Follow the Identity Provider-specific configuration steps that appear:
What information will Superhuman Mail need to configure SAML for your organization?
To set up SAML, you’ll need to provide our team with the following information:
  • The email address of your organization’s Identity Provider administrator.
  • Any domains that will be used for authentication.
  • Any email addresses that should be excluded from SAML policies.
What’s the difference between SSO with a Google/Microsoft account vs. Superhuman Mail?
If configured, users will still be prompted for SSO when logging into their email provider (Google or Microsoft). Superhuman Mail's SAML implementation adds a layer of application-specific authentication.
Is Just-in-Time (JIT) Provisioning supported?
No, Superhuman Mail does not support JIT Provisioning via SAML.
Pricing
SAML Authentication is available as part of Superhuman Mail's Enterprise plan. If this plan fits your organization’s needs, please contact us to learn more.
