Feature availability
- Works in: Superhuman Mail in Claude (Claude Chat, Claude Code, and Cowork)
- Plans: Superhuman Mail Enterprise plan with SAML configured; Claude Team or Enterprise plan
Enterprise-Managed Authorization (EMA) lets admins give people access to Superhuman Mail in Claude centrally, so no one has to authenticate the connector individually. Once it’s on, your team connects with one click.
Before you begin
EMA is for IT admins and Claude organization Owners who are on a Superhuman Mail Enterprise plan. Make sure you have:
- A Claude Team or Enterprise plan, and Owner or admin access to it.
- A Superhuman Mail Enterprise plan with SAML configured. EMA only works for organizations with SAML set up. If you haven’t set it up yet, contact your Customer Success Manager (CSM).
- For Okta-issued setup only: admin access to Okta.
- For Claude-issued setup only: your Superhuman Mail CSM, who enables it for you.
Choose your setup option
There are two ways to set up EMA. The right one depends on your identity provider (IdP), the service that manages your team’s sign-ins.
- Okta-issued: Okta issues the identity assertion (ID-JAG) for your users. Choose this if your IdP is Okta.
- Claude-issued: Claude issues the identity assertion, so you don’t need Okta. Choose this if your IdP isn’t Okta.
Option A: Okta-issued
- In the Okta Admin Console, add Superhuman Mail as an app that supports Cross App Access (XAA).
- Assign the users or groups who should have access.
- In the Claude admin console, go to Connectors and select Superhuman Mail.
- Under Managed authorization, turn on Enterprise-Managed Authorization.
- Run the token exchange test and confirm each step passes.
Note: Until the Okta Integration Network (OIN) listing is live, you may need to create a custom app. See Okta’s Cross App Access participation guide.
Option B: Claude-issued
- Contact your Superhuman Mail CSM. Not sure who that is? Email hello@superhuman.com.
- Your CSM enables Claude-issued EMA for your organization and sends you a link to a configuration page. Complete the configuration there.
- In the Claude admin console, go to Connectors, then search for and select Superhuman Mail.
- Under Managed authorization, turn on Enterprise-Managed Authorization, then select Claude-issued assertions.
What your users will see
Users open Claude and connect to Superhuman Mail with one click, with no extra authentication.
If someone isn’t assigned in Okta (Okta-issued) or has never signed in to Superhuman Mail, they’ll see the standard Connect prompt or an error.
Troubleshooting
The token exchange test shows an error that the user isn’t provisioned for the app
The user is missing an app assignment in Okta (Okta-issued), or hasn’t signed in to Superhuman Mail yet. Assign the user, have them sign in to Superhuman Mail once, then run the test again.
Managed authorization doesn’t appear for Superhuman Mail in the Claude admin console
Confirm you’re on a Claude Team or Enterprise plan. If you are, contact Claude support.
The connection works for some users but not others
Check which authentication method your organization uses:
- Claude-issued assertions: Make sure the user’s Claude email address matches their Superhuman Mail email address.
- Okta SSO: The match uses an internal Okta ID, not the email address. If only some users can connect, contact your Superhuman Mail CSM so we can look into it.
Does EMA work with Gmail and Outlook accounts?
Yes. EMA works with both Gmail and Outlook accounts that are signed into Superhuman Mail.
Do I need Okta?
Only for Okta-issued assertions (Option A). If your IdP isn't Okta, use Claude-issued assertions (Option B), which don't need Okta. Either way, your organization needs SAML configured with Superhuman Mail.
Does EMA change my Superhuman Mail permissions?
No. EMA doesn’t add new permissions.
How do I turn off EMA?
For Okta-issued setups, unassign the user or app in Okta. For Claude-issued setups, remove the user from your Claude organization. To turn it off for everyone for either setup, turn off Managed authorization for Superhuman Mail in the Claude admin console.
