Coursework Helper user guide
The Coursework Helper agent organizes a student’s assignments and deadlines across multiple courses by connecting through the Canvas connector in Go. It helps students plan their week, study for exams, and identify the next step to complete assignments on time.
Note: The Coursework Helper agent is currently available in beta to Free and Pro users through the Superhuman Go browser extension for Google Chrome and at go.superhuman.com. We’re rolling out this agent’s features gradually. Please contact the Customer Care team with any related questions.
Getting started
Note: If you have chosen the Student role when creating your account, the Coursework Helper agent will be pre-installed for you.
In Canvas
  1. If you have Superhuman Go up and running, you’ll see a prompt to install the Coursework Helper agent when you log in to your Canvas account. Click Open agent:
  2. Click Agents in the upper-left corner and add the agent if it’s not listed there. Look for Coursework Helper.
  3. Once you select Coursework Helper, the agent will pull all available assignments and information from your Canvas account to provide suggestions and next steps.
In the Superhuman Go browser extension
  1. Open the Superhuman Go browser extension for Google Chrome and click the menu icon in the upper-left corner:
  2. In the Agents section, click See more. In the menu that appears, select Browse Agents and search for the Coursework Helper agent in the search field that opens next:
  3. Click Open. Read the details on how the agent works and handles your data in the window that opens next, then click Open agent.
  4. Finalize the installation by configuring the Canvas connector in the window that opens next. Open Canvas in another tab and sign in as usual, or go straight there using your school’s address.
  5. Click Done. Once completed, you’re all set!
On the Superhuman Go home page
  1. Go to go.superhuman.com and click the menu icon in the upper-left corner:
How to use Coursework Helper
Once you install the Coursework Helper agent, you can tailor it to your current needs. The Suggested tasks section suggests tasks based on your coursework. The All coursework section determines a list of tasks based on the set deadlines. The agent shows you only the relevant upcoming tasks. You don’t need to add your courses to the Coursework Helper manually, as the Canvas connector automatically connects all tasks.
How to deactivate the Coursework Helper agent and delete the synced data
You can disconnect the Canvas connector in the Coursework Helper agent settings and delete all synced data at any time.
  1. Click the settings icon in the upper-right corner of the agent menu.
  2. Coursework agent settings will open in a new tab. To delete your data, click the three dots icon (⋮) and choose Remove.
