You can silently install Superhuman Go for Chrome on multiple computers at once using a managed software solution or deployment mechanism.
Group Policy
Registry Key
Chrome Policy
Admin Console
In your Microsoft Windows Group Policy Editor (Computer or User Configuration folder):
  1. Go to Administrative Templates → Google → Google Chrome Extensions.
  2. Open Extension management settings.
    Note: If you don’t see the policy, download the latest policy template.
  3. Enable the policy and enter its compact JSON data in the text box.
    Note: Enter JSON data as a single line with no line breaks (example JSON data below).
  4. Set the following app and extension policy:
    { "fiicfmbdhpbnebmbofpphmalhgofdakc": { "installation_mode": "force_installed", "update_url": "https://clients2.google.com/service/update2/crx" } }
  5. After you deploy a Chrome extension policy, check user devices to ensure the policy was applied correctly.
  6. On a managed Chrome device, go to chrome://policy.
  7. Click Reload policies.
  8. In the upper-right corner, in the Filter policies by field box, enter ExtensionSettings.
  9. Check the Show policies with no value set box.
  10. Under the Chrome policy name next to each extension setting, make sure Status is set to OK.
  11. Click Show value and ensure the value field isn’t empty.
  1. Find or create the following key in the registry:
    • 32-bit Windows: HKEY_LOCAL_MACHINE\Software\Google\Chrome\Extensions
    • 64-bit Windows: HKEY_LOCAL_MACHINE\Software\Wow6432Node\Google\Chrome\Extensions
  2. Create a new key (folder) under the Extensions key called "fiicfmbdhpbnebmbofpphmalhgofdakc".
  3. In your extension key, create an "update_url" property and set it to this value: "https://clients2.google.com/service/update2/crx"
In your Chrome configuration profile:
  1. Update the ExtensionSettings key and add the following entry:
    <key>fiicfmbdhpbnebmbofpphmalhgofdakc</key> <dict> <key>installation_mode</key> <string>force_installed</string> <key>update_url</key> <string>https://clients2.google.com/service/update2/crx</string> </dict>
  2. After you deploy a Chrome extension policy, check user devices to ensure the policy was applied correctly.
  3. On a managed Chrome device, go to chrome://policy.
  4. Click Reload policies.
  5. In the upper-right corner, in the Filter policies by field box, enter ExtensionSettings.
  6. Check the Show policies with no value set box.
  7. Under the Chrome policy name next to each extension setting, make sure Status is set to OK.
  8. Click Show value and ensure the value field isn’t empty.
  9. Launch the browser and go to chrome://extensions; you should see the extension listed.
  1. Go to the Google Admin Console → Chrome browser → Apps & extensions.
  2. Select the OU/Group that should get the Superhuman Go browser extension.
  3. Click the yellow plus icon in the lower-right corner of your screen and select Add from Chrome Web Store:
  4. In the Search bar, type Superhuman Go and click Select.
We recommend changing the Installation policy to Force install and pinning the extension to the browser toolbar to increase visibility.
If you’re looking to enable Managed Mode for your team, add this to the Policy for extensions field.
