Manage Superhuman Go settings
The Go settings page allows you to customize how the Go assistant works for your team.
  • Superhuman Go: Lets you control who has access to Go.
    • To enable access to Go for everyone, select Entire organization.
    • To grant access to specific member groups, select Specific groups, then check the boxes next to the groups that should have access. Click Apply Groups to save changes.
  • Search the web: Control whether the Go assistant and agents can access the web. It can be set to on or off for the entire organization.
  • Share agents: Control whether team members can publish agents internally. Can be enabled or disabled for the entire organization.
  • Create custom agents: Control whether users can build and customize their own agents in your organization.
    • To enable it for everyone, select Entire organization.
  • Request access to connectors and agents: Enable users to request that admins grant access to connectors and agents.
