Configure Superhuman connectors
The Connector controls page lets you manage all available Superhuman connectors to external sources. The library is constantly expanding, with new integrations added regularly.
Approve connectors
With the Require approvals setting enabled, all new connector installations will require approval from a subscription admin.
If this setting is enabled, the connectors and agents currently in use will remain enabled, and the rest will be deactivated. After that, you can pre-approve any of the deactivated connectors or configure policies as needed.
If the Require approvals setting is turned off, all available connector and agent installs will be allowed.
Configure a connector
Clicking a connector opens a page with its details and configuration options.
The Connector access section lets you set availability to Everyone, No one, or Custom.
Setting Connector access to Custom reveals the Configurations section. To change an existing configuration, click Edit next to it. To create an additional configuration, click + Add Configuration under the existing one.
Configurations allow you to specify member access, read and write permissions (with Allow, Always Ask, or Deny options), OAuth scopes, and more.
The Connector details section shows the domains a connector is linked to and the apps it operates in.
For configuration instructions for specific connectors, see the Connectors section.
