Manage Superhuman agents
The Agents page allows you to configure and manage the following agents:
Clicking an agent opens a page with its details and configuration options. On Enterprise plans, the admin can also control which member groups can access a given agent.
Agent access can be assigned to All users, No users, or set to Custom by selecting the corresponding option from the dropdown menu in the Agent access section.
The Custom access option lets you select the member groups for whom the agent will be available.
The Agent details section shows the domains to which an agent is connected and the apps where the agent operates.
