Multi-Connector Workflows for the Superhuman Mail MCP
Your best work often needs more than your inbox — it needs context that lives in your other tools, like a Slack thread, a note in your CRM, or last week's call notes.
Connect the other tools you already use, and every prompt and skill gets sharper — your assistant can pull from all of them at once, not just your inbox.
 Connect another tool
Adding another tool works just like connecting Superhuman Mail — find it in your AI tool's connector settings and sign in:
  • Claude: Customize → Connectors → search for the tool → Connect.
  • ChatGPT: Plugins → search for the tool → Install.
That's all it takes. Whether it's Slack, your CRM, Granola, or Linear, the steps are the same — and your assistant can now pull from every tool you connect.
⚡ Try It Now (optional)
  1. Connect Slack the same way you added Superhuman Mail.
    1. Claude: Customize → Connectors → search Slack → Connect.
    2. ChatGPT: Plugins → search Slack → Install.
  2. Sign in with your Slack account.
  3. Copy and paste:
Use Superhuman Mail and Slack to find my latest email from [person], check my team’s Slack for any relevant discussion, and draft a reply that pulls it together.
Your assistant reads the email, scans Slack for what your team already said, and hands you a draft that reflects both, so you’re not switching tabs or asking a teammate, “what did we decide on this?”
More workflows to try
The more tools you connect, the more your assistant can do.
Start any prompt with “Use Superhuman Mail and [tool] to…” then say what you need:
  • Mail + CRM: pull [company]'s deal history into a reply.
  • Mail + meeting notes: turn last call's action items into follow-up emails.
  • Mail + Linear: check [project]'s status, then draft a reply.
💡 Tip: Skills like Deal Tracker and Batch Draft Writer get richer as you connect more tools, pulling context from wherever it lives to make every briefing and draft more complete.
You’re all set!
You’ve connected your inbox, delegated the busywork, saved your favorite workflows as skills, and taught your assistant to work across every tool you use. That’s the whole point of the Superhuman Mail MCP — less time in your inbox, more done on your behalf.
Congratulations!
🎉 You’ve completed the Drive Superhuman Mail from Claude or ChatGPT guide and are ready to fly through your inbox faster than ever!
