Drive Superhuman Mail from Claude and ChatGPT
Your inbox holds hours of work every week — triage, follow-ups, context-gathering, the busywork between the real decisions. The Superhuman Mail MCP hands that work to your AI assistant.
Connect Superhuman Mail to Claude, ChatGPT, or your other AI tool. From there, your AI assistant can see your email, contacts, and calendar — enough to sort through your morning, check Read Statuses, draft multiple replies at once, and more — so the busywork of email handles itself while you focus on the work that actually needs you.
🎯 In this Guide, you'll learn how to:
  • Set up the MCP
  • Run strong prompts
  • Leverage MCP skills
  • Build multi-connector workflows
In just 15 minutes, you’ll have everything you need to get up and running with the Superhuman Mail MCP.
Prefer a walkthrough instead? Watch our on-demand version anytime and start getting the most out of the Superhuman Mail MCP today.
Let’s start with connecting your AI tool👇
