Error: “We found a problem. Your doc is safe, and we have been notified.”
If you’re receiving this error message when opening your document, please follow the steps below.
Check if there’s enough storage space on your local drive
This issue may occur if there is not enough storage space on your device. Please check your available storage space and follow these instructions to free it up if needed:
If there is enough storage space on your device, follow the instructions below for your browser.
Chrome
Edge
Firefox
Safari
Check if the issue reproduces in incognito mode
  1. Open Chrome.
  2. Paste the following link into the address bar and open it: chrome://extensions
  3. Under Grammarly: AI Writing Assistant and Grammar Checker App, click Details:
  4. Turn on the Allow in Incognito option:
  5. Open an incognito window by pressing Command + Shift + N on Mac or Ctrl + Shift + N on Windows, Chromebook, or Linux.
  6. Sign in to your account at www.grammarly.com/signin.
  7. Go to app.grammarly.com and check whether the issue persists in incognito mode.
If the issue doesn’t reproduce in incognito mode, it indicates that other browser extensions may be causing it. Try turning off other extensions to see if the issue still occurs.
Turn off other browser extensions
  1. Open a new tab in Chrome.
  2. Paste the following link into the address bar: chrome://extensions
  3. Turn off all other extensions.
  4. Go to app.grammarly.com and check whether the issue still occurs.
If the issue no longer occurs, it means one of your browser extensions was causing it. To find the one that may have been causing it, try turning on the other extensions one by one.
Turn on other browser extensions one by one
  1. Go back to chrome://extensions
  2. Turn on one of the extensions.
  3. Go to app.grammarly.com and check whether the issue still occurs.
  4. If the issue doesn’t reproduce, turn on another extension and check again.
If you encounter the error again after turning on an extension, it means the last extension you turned on is likely the one causing it.
If the previous instructions didn’t resolve the issue, try this
If the previous instructions didn’t resolve the issue, it may be due to corruption of the indexed database. To fix it, follow these steps:
  1. Go to app.grammarly.com.
  2. Right-click on the center of the page and select Inspect.
  3. In the console that opens, click on the >> icon and select the Application tab from the dropdown menu:
  4. In the left-side panel, select Storage.
  5. Under Storage, uncheck all items except IndexedDB and click Clear site data above:
  6. Refresh the page.
  1. Open Edge.
  2. Paste the following link into the address bar and open it: edge://extensions
  3. Under Grammarly: AI Writing Assistant and Grammar Checker App, click Details.
  4. Check the box next to Allow in InPrivate.
  5. Open an incognito window by pressing Command + Shift + N on Mac or Ctrl + Shift + N on Windows.
  1. Open a new tab in Edge.
  1. Go back to edge://extensions
  1. Open Firefox.
  2. Click the main menu icon in the upper-right corner of your Firefox window.
  3. Select Add-ons and themesExtensions.
  4. Click on the Grammarly browser extension to expand more options.
  5. Under Run in Private Windows, select Allow.
  6. Click the main menu icon and select New Private Window.
  7. Sign in to your account at www.grammarly.com/signin.
  8. Go to app.grammarly.com and check whether the issue persists in incognito mode.
  1. Open a new tab in Firefox.
  2. Paste the following link into the address bar and press Enter: about:addons
  1. Go back to about:addons
  3. In the console that opens, go to the Storage tab.
  4. Open the Indexed DB menu in the left-side panel.
  5. Expand the http://coda.grammarly.com menu.
  6. Right-click on the idb_uncommitted (default) item and select Delete “idb_uncommitted (default).”
  7. Refresh the page.
  1. Open Safari.
  2. In the upper-left corner, open the File menu.
  3. Select New Private Window​.
  4. Sign in to your account at www.grammarly.com/signin.
  5. Go to app.grammarly.com and check whether the issue persists in incognito mode.
  1. Go to SafariSettings… or press Command ⌘ + Comma.
  2. Select the Extensions tab.
  1. Go back to SafariSettingsExtensions.
If none of the steps above helped, please contact Support. To help resolve the issue more quickly, please provide the following:
  • Direct link (URL) to the document for which you’re receiving the error.
  • (Optional) Original text or document where the issue can be reproduced.
Note: Support Engineering team members may need to view your document to identify the cause of the issue.
  • Specify whether the issue occurs with any document you create or upload at app.grammarly.com or only with specific documents.
  • Add a video recording of the issue.
