The Superhuman Go browser extension for Google Chrome and Microsoft Edge is a proactive AI assistant that works alongside you across the web, understanding what you’re working on and stepping in with the right support at the right time.
It brings AI directly into your workflow, so you can stay focused without switching tools or losing momentum.
Note: If you also use Superhuman Go for Windows and Mac, the browser extension will be turned off by default on most websites, but will remain active in Google Docs.
To check whether the extension is installed, look at your browser toolbar. You’ll see the Superhuman Go icon if the extension is active:
Note: You can pin the Superhuman Go browser extension to your toolbar for easier access. To do that, select the puzzle icon in the upper-right corner of the browser window and click the pin icon.
Once the extension is installed, you’ll see writing suggestions as you type on different websites.
Checking text
When you click into a text field, you should see inline underlines across your text. As you keep typing, the Grammarly agent will analyze your text dynamically.
Note: Superhuman Go does not initialize in text areas smaller than 38 pixels in height.
After the Grammarly agent finishes analyzing your text, it displays writing suggestions as inline underlines directly in the text. To accept a suggestion, hover over the underlined text and click the suggestion card that appears.
Suggestions will also appear in a list view when opening the Grammarly agent. Click its icon to open it in the Superhuman Go sidebar:
Alternatively, click Open Grammarly on any suggestion card to automatically open the Grammarly agent.
To review a suggestion, click it in the sidebar. To accept it, select Accept on the corresponding suggestion card:
If Grammarly flags an unfamiliar word and you’re sure it’s spelled correctly, you can dismiss the suggestion by clicking X:
Using generative AI
The Superhuman Go browser extension is powered by generative AI. To use generative AI features, open the Superhuman Go tab to access Go.
To learn more about AI agents, check out this article: About Superhuman Go agents
You can also rewrite or improve your text by using the paragraph-level rewrites feature that appears as a “hero” icon once you select your text. Paragraph-level rewrites allow you to improve, rephrase, or shorten your text, or make it friendly or formal. You can also enter your own prompt to specify your preferred style.
Uploading files to Superhuman Go
You can upload files to the Superhuman Go chat so Go can use them as context when responding to your prompts. For example, you can attach a document and ask Go to summarize it, or attach a screenshot and ask for feedback.
Note: File uploads are available to both Superhuman Free and Pro plans
To upload a file:
- In the Go chat, click the + button in the lower-left corner of the chat box.
- Select Add photos and files.
- Choose the files you want to upload from your device.
- Click Open to attach them.
You can also attach files by dragging and dropping them into the chat window, or by copying an image and pasting it from your clipboard into the chat.
Supported file types
| File type | Supported formats |
| Images | JPEG, PNG, GIF, WebP |
| PDF files | |
| Spreadsheets | .xls, .xlsx, .xla, .xlb, .xlc, .xlm, .xlt, .xlw, .csv, .tsv, .iif; Google Sheets |
| Documents | .doc, .docx, .dot, .odt, .rtf; Pages; Google Docs |
| Presentations | .ppt, .pptx, .pot, .ppa, .pps, .pwz, .wiz; Keynote; Google Slides |
| Text and code | .txt, .md, .markdown, .html, .htm, .css, .js, .mjs, .json, .xml, .py, .c, .cc, .cpp, .cxx, .h, .hh, .sql, .log, .eml, .ics, .vcf, .srt, .vtt, and other common text and code formats |
Upload limits
- File size: Up to 7 MB for images (PNG, JPEG, WebP, GIF) and up to 30 MB for all other file types.
- Number of files: Up to 5 files per chat.
Deactivating certain suggestion types
Certain types of suggestions, such as adding the Oxford comma or flagging passive voice, can be turned off. You can view and manage suggestions on the Your preferences page.
Note: This feature is available only in Superhuman or Grammarly Pro, Superhuman or Grammarly Business, Grammarly Plus, and Grammarly for Education plans. Deactivated suggestions will be turned off across all Superhuman product offerings you use.
Using definitions and synonyms
The Superhuman Go browser extension includes various features to help you improve your writing, such as looking up definitions or synonyms.
You can check the definition of a word and its synonyms on any website by double-clicking it.
Adjusting language preference and managing settings
You can adjust your preferences by clicking the Superhuman Go icon in your browser’s toolbar to open the Settings panel.
Here, you can:
- Turn off the Superhuman Go browser extension for a particular website
- Activate or deactivate the definitions and synonyms feature
- Manage Grammarly features
- Activate Grammarly Authorship
- Edit shortcuts
- Change your language preference
- Create a new document or access your dashboard in docs
- Activate the auto-citations feature
