How to choose where Superhuman Go for Windows and Mac works
With Superhuman Go for Windows and Mac, you can choose which apps you’d prefer Superhuman Go not to initialize in.
Note: This option is temporarily unavailable on Windows, but is coming soon. The steps below apply to Superhuman Go for Mac.
If you’d like to prevent Superhuman Go from initializing on a specific website or application, follow these steps:
  1. Place your cursor in a text field in the app or on the website where you’d like to turn off Superhuman Go.
  2. On Mac, click the Superhuman icon in the menu bar and select Superhuman Go:
  3. Choose Turn off Superhuman Go or Turn off Superhuman Go for 1 hour.
To manage blocked applications or websites, navigate to SettingsBlock list, where you can remove previously added items.
