Choose where Superhuman Go for Windows and Mac works
With Superhuman Go for Windows and Mac, you can choose which apps you’d prefer Superhuman Go not to initialize in.
To prevent Superhuman Go from initializing on a specific website or application on Windows, follow these steps:
  1. Place your cursor in a text field in the app or on the website where you’d like to turn off Superhuman Go.
  2. Click the Superhuman tab that appears on the right side of the screen and choose Turn off suggestions for 1 hour or Turn off suggestions:
Superhuman Go for Mac
To prevent Superhuman Go from initializing on a specific website or application on Mac, follow these steps:
  2. Click the Superhuman icon in the menu bar and select Turn off Superhuman Go for 1 hour or Turn off Superhuman Go:
To manage blocked applications or websites, navigate to Settings → Block list, where you can remove previously added items.
