How Grammarly protects your privacy on Android
Grammarly works in tandem with your operating system to provide feedback about your writing across a wide range of supported apps on your mobile device. To offer this experience, Grammarly needs overlay permission and access to accessibility features on your device. Without this, our product will not be able to provide writing assistance.
Be assured that Grammarly analyzes only your text and provides suggestions in the text field you are writing in. When Grammarly isn't active, the floating Grammarly widget disappears, meaning that Grammarly isn't accessing your text at that moment. Grammarly does not collect or analyze text outside the text field you are writing in.
You can read about our enterprise-grade security and commitment to trust at https://www.grammarly.com/trust
