Included in: Grammarly Enterprise plans
Managed by: Admins
This guide provides the steps required to configure SCIM provisioning for Grammarly in Okta. For general information about SCIM provisioning, please see this article: Configure SCIM provisioning
Features
The following provisioning features are supported in Okta:
  • Create users in Grammarly
  • Remove users in Grammarly when they no longer require access
  • Keep user attributes synchronized between Okta and Grammarly
  • Keep groups and group membership synchronized between Okta and Grammarly
Note: The SCIM group provisioning support is available for Grammarly Enterprise customers upon request. If you’re interested in enabling this feature, please contact your Customer Success Manager or Grammarly Support team.
Requirements
Step-­by-­Step Configuration Instructions
  1. Log in to your Grammarly account, go to the Provisioning page, and click Configure.
  2. Click the Activate SCIM button
  3. Generate a SCIM token by clicking the Create token link
  4. Copy the SCIM token for future use, click Got it, and close the window.
  5. Check the Enable provisioning features box.
  6. Click Configure API Integration.
  7. Check the Enable API integration box.
  8. Enter the API Token provided by Grammarly (see Step 4 above).
  9. Click Test API Credentials. If successful, a verification message will appear at the top of the screen.
  10. Click Save.
  11. Select To App in the left panel, then select the Provisioning Features you want to enable.
Provisioning of existing users
If you’re adding the provisioning capability to an existing Grammarly application, you will need to provision the existing users before they can log in.
To do this, go to the Assignments tab on the apps configuration page and click the Provision User button, which will appear after you’ve completed the configuration instructions above.
Here you will be able to bulk-provision users. After this provisioning step is complete, all assigned users will be able to log in.
Note: If you don’t see this option, please contact Okta support to have it enabled. With this option, you will be able to bulk-provision all assigned users.
Resolve Issues
  • When users are deactivated in Okta, they will be deactivated in Grammarly. Users will not be able to log in to the application, but their data will remain available as an “inactive user.” After 30 days, their accounts will be deleted completely.
