Does Grammarly support languages other than English?
In addition to English, Grammarly supports suggestions in the following languages:
  • Spanish
  • French
  • Italian
  • German
  • Portuguese
  • Turkish
  • Polish
  • Dutch
  • Czech
  • Ukrainian
  • Vietnamese
  • Hungarian
  • Swedish
  • Romanian
  • Indonesian
  • Slovak
  • Danish
  • Finnish
  • Norwegian
  • Tagalog
  • Korean
  • Hindi
  • Japanese
  • Chinese
Multilingual suggestions are included in all Grammarly plans—Free, Pro, Enterprise, and Education. To get started, begin writing in any of the supported languages. Whenever a suggestion is available, users will see red or blue underlines indicating the recommended change.
Grammarly also supports paragraph-level rewrites in Spanish, French, Italian, German, Portuguese, and Ukrainian. Grammarly also supports translation. For more details, visit these pages:
Grammarly also recognizes spelling, grammar, and punctuation differences across American, British, Canadian, Australian, and Indian English.
You can change your language preference on the Language settings page.
You can also set up your language preference in Grammarly for Windows and Mac.
If you use Windows PC:
  • Click the floating Grammarly widget.
  • Then, click the gear icon in the upper-right corner of the pop-up.
  • Go to Customization and select your preferred option next to I write in.
If you use a Mac:
  • Click the Grammarly icon in the menu at the top of your screen and select Settings.
You can learn more in this article: How to Select Your English Dialect
