Requirements
• JumpCloud Administrator account
• Grammarly Business, Grammarly Enterprise, or a Grammarly for Education account with the admin role or a designated custom role
  1. Log in to the JumpCloud Admin Portal.
  2. Go to USER AUTHENTICATION → SSO Applications.
  3. Click + Add New Application.
  4. In the Search field, type “Grammarly” and select it.
  5. Click Next.
  6. In the Display Label field, type your name for the application. Optionally, fill in the Description field, change the User Portal Image, and choose to hide or Show in User Portal.
  7. Optionally, expand the Advanced Settings section to specify a value for the SSO IdP URL. If no value is entered, it will be set to https://sso.jumpcloud.com/saml2/<applicationname>.
  8. Click Save Application.
  9. Next, click Configure Application and select the SSO tab.
  10. Add or change any attributes.
  11. Click Save.
To enable SSO in your Grammarly account, you will need to enter your JumpCloud IdP Entity ID, JumpCloud IDP URL, and your certificate.
To download the certificate:
  1. Find your Grammarly application in the Configured Applications list and click to open in.
  2. Select the SSO tab and click on IDP Certificate Valid → Download certificate.
For more information, please review this article from JumpCloud: Integrate with Grammarly
To enable SSO in your Grammarly account, follow these steps:
  1. Log in to your Grammarly account, go to the Authentication page, and click Configure.
  2. In the Identity Provider Issuer field, enter your JumpCloud IdP Entity ID.
  3. In the SAML 2.0 Endpoint (HTTP) field, enter your JumpCloud IDP URL.
  4. Paste your certificate into the Certificate field.
  5. Click Test SSO. If the test is successful, click Activate SSO.
If the SSO test has failed, please double-check the Grammarly app settings in your identity provider and the values you entered on the Authentication page. If you encounter any other issues, please search for more information on this page: Resolve Issues
