How to deactivate or uninstall Grammarly for Safari on iOS
You can turn off Grammarly on a specific website forever or until the next visit by tapping the power button in the text field.
If you’d like to permanently deactivate Grammarly for Safari on your iOS device, follow these steps:
  1. Open Settings and go to Safari.
  2. Tap Extensions.
  3. Turn off Grammarly.
This action will prevent Grammarly from providing suggestions via the Grammarly browser extension.
If you’d like to uninstall Grammarly for Safari on iOS, you will need to uninstall the Grammarly Keyboard for iOS as well. To do that, tap and hold the Grammarly companion app icon and then in the menu that appears, tap Remove App
