Requirements
- Microsoft Entra ID (Azure AD) account with access to the administrator console
- Log in to your Microsoft Entra ID admin account and go to Azure Active Directory.
- Navigate to Enterprise Applications and select New application.
- Search for Grammarly, click on the app, and click Create in the panel that opens.
- On the next page, click Set up single sign on and choose SAML as your single sign-on method.
In the Basic SAML Configuration section, the application is pre-configured, and the necessary URLs are already pre-populated. Please click Yes to save the default settings:
- Grammarly application expects the SAML assertions in a specific format. These attributes are also pre-populated but you can review them as per your requirements.
On the Set up single sign-on with SAML page, in the SAML Signing Certificate section, find Certificate (Base64) and click Download to save it on your computer:
In the Set up Grammarly section, copy Login URL and Microsoft Entra Identifier. You will need to enter these values in your Grammarly account accordingly:
- Microsoft Entra Identifier → Identity Provider Issuer
- Login URL → SAML 2.0 Endpoint (HTTP)
Certificate (Base 64) → Certificate (you will need to open the file in a text editor and copy the contents to Grammarly)
To assign users to the Grammarly application in Microsoft Entra ID, please do the following:
- In the Microsoft Entra ID portal, select Enterprise Applications.
- In the applications list, select Grammarly.
- In the application’s overview page, find the Manage section and select Users and Groups.
- Select Add user/group, then select Users and groups in the Add Assignment dialog.
- In the Users and groups dialog, select the appropriate users or groups then click the Select button at the bottom of the screen.
- In the Add Assignment dialog, click the Assign button.
Lastly, to activate SSO for your organization’s Grammarly account, follow these steps:
- Sign in to your Grammarly admin account.
- Go to the Authentication page and click Configure.
- Fill out the required fields with the parameters from your identity provider:
- In the Identity Provider Issuer field, enter your Microsoft Entra Identifier.
- In the SAML 2.0 Endpoint (HTTP) field, enter your Login URL.
- In the Certificate field, paste your Certificate (Base 64).
- Click Test SSO.
- If the test is successful, click Activate SSO.
Note: There might be a delay in propagating the SSO parameters from Microsoft Entra ID to Grammarly. To avoid issues with configuring SSO, we recommend enabling SSO on the Grammarly side 1–2 hours after setting up the Grammarly app in Microsoft Entra ID.
