Managing your keyboard settings in Grammarly for iPhone
Grammarly for iPhone offers several ways to customize your writing experience. If you use Grammarly as a keyboard, you can see the list of changes you can apply by opening the Grammarly companion app and tapping Keyboard:
Note: If you use the Grammarly Editor on your iPad, see this article: Managing your settings in Grammarly for iPad
Customization options
Grammarly for iPhone offers the following customization options:
To turn any of these options on or off, switch the toggle next to them.
Note: Grammarly for iPhone now supports a built-in text replacement feature on iOS, allowing you to easily expand abbreviations or shortcuts into full phrases or words as you type. To manage text replacement on your iPhone, tap SettingsGeneral Keyboard Text Replacement.
Language Preference and Personal Dictionary
To manage your language preference in Grammarly for iPhone, open the Grammarly companion app and tap Account.
To learn more about the language preference feature, check out this article: How to Select Your English Dialect
To access your personal dictionary, go to Account and tap Manage Personal Dictionary.
To add new words, press the Plus icon (+) in the upper-right corner of your screen. In the pop-up window, type in the word and select Add:
To remove a word from your personal dictionary, locate the word you’d like to delete and swipe to the left until the red Delete button appears. Then, tap the Delete button to remove the word.
Smart Formatting
Smart Formatting helps you write numbers, measurements, and expressions more easily. As you type, the Grammarly Keyboard recognizes things like math, units, long numbers, phone numbers, and times, and offers a ready-to-use result or a cleaner format right in the suggestion bar. Nothing changes automatically — you can tap a suggestion to apply it.
Turn Smart Formatting on or off
  1. Open the Grammarly app on your iPhone.
  2. Tap the Keyboard tab, then tap Smart Formatting.
  3. Turn each option on or off. They’re all on by default, so you can keep the ones you find useful and switch off the rest.
What each setting does
  • Show Math Results: Calculates arithmetic expressions and offers the result.
  • Show Unit Conversions: Converts measurements to equivalent values in other units.
  • Show Number Formatting: Suggests readable formatting for long numbers and ratios.
  • Show Phone Number Formatting: Applies standard formatting to phone numbers.
  • Show Time Conversions: Converts between 12-hour and 24-hour time.
Smart Formatting in action
Here are a few examples of what you’ll see in the suggestion bar as you type:
You type Grammarly offers
1256/(54+3)^2 0.38658
1000000 one million · 1M · 1,000,000
+48720123456 +48 720 123… · +48-720-12…
Text me at roman@ outlook.com · gmail.com · yahoo.com
In Berlin, the temperature was 40C 104°F · 313.2 K
Let’s meet at 05.05 5/5 · May 5
He drove over 30mph 48.28 km/h · 13.411 m/s
To use a suggestion, just tap it in the bar, and it will replace what you typed. If you’d rather keep your original text, keep typing, and the suggestion will disappear.
Don’t see the suggestions you expect? Make sure the Grammarly Keyboard is enabled on your iPhone (SettingsGeneralKeyboardKeyboards), and that the setting you want is turned on under KeyboardSmart Formatting.
