You may be able to solve a problem by reinstalling Grammarly for Android, but be aware that doing so will cause you to lose Drafts. (See note below.)
To reinstall Grammarly for Android, follow the steps below:
  1. Uninstall your current version of the Grammarly app.
  2. Search for Grammarly in the Google Play Store.
  3. Tap Install next to the Grammarly for Android listing to start the installation.
  4. Once it’s installed, follow the onscreen instructions to complete the setup process.
Note: When you reinstall Grammarly for Android, all notes in your Drafts will be deleted. If you have any important information stored in Drafts, please make sure to copy it to a safe location before reinstalling the application.
