Paraphraser agent user guide
The Paraphraser agent helps you rephrase your writing to better match your goals, style, and audience. Choose from six preset styles that transform your entire document with targeted, paragraph-level rewrite suggestions, or create your own voice profile to help ensure any document you write sounds more like you. Paraphraser gives you control and flexibility—all in a few clicks.
Availability
The Paraphraser agent is available in Superhuman Go and in docs, for Grammarly Pro and Grammarly Plus subscribers. Users of Grammarly Free have a limited number of suggestions per day.
If you’re on the Free plan, consider upgrading to Pro to unlock the benefits of the advanced writing suggestions. Visit www.grammarly.com/plans to see what Pro has to offer and choose a plan that best suits your needs.
For Grammarly Enterprise, Grammarly Business, and Grammarly for Education users, the Paraphraser agent is accessible in docs. When docs is enabled, agents are on by default. Admins can adjust agent access for team members on the Agent access page.
How to use
To access the Paraphraser agent, click its icon on the right side of your document:
Choose a writing style that fits your goals. You can choose from Humanize, Academic, Professional, Streamlined, Creative, or Simple. Suggested edits will appear as paragraph-level rewrites on the left-hand panel overlaid on your text.
You can accept or dismiss suggestions, or undo individual edits—so you're always in control of your content.
Create a custom voice
You can create a custom voice to ensure your writing always sounds the way you want it to:
  1. Click the Create a voice button.
  2. Name your voice and add a few writing examples to help the tool learn your tone.
  3. Once it’s saved, your voice will appear in the list of available writing styles.
Select your custom voice to have Grammarly suggest rewrites in your style. You can create multiple voices and delete any that no longer serve your needs.
Note: Voice profiles are shared across the Paraphraser and Humanizer agents.
