Error: Can't connect to Grammarly or Something went wrong
Important: Sometimes, this issue can be solved by simply restarting your computer. Make sure that you do so before proceeding to the steps below.
The error message “Something went wrong” or a gray Grammarly widget is usually caused by restrictions within your network, VPN, proxy, or firewall settings.
To resolve this, you need to ensure that your network, firewall, VPN, or proxy allows access to the following internet addresses:
  • *.grammarly.com (ports 80 and 443)
  • *.grammarly.io (ports 80 and 443)
  • *.grammarly.net (ports 80 and 443)
You or your IT administrator may need to add exception rules for the above addresses to your network, firewall, VPN, or proxy settings.
Additionally, Grammarly apps use WebSockets to communicate with our servers, with the corresponding ports of 80 and 443. Besides allowing the URLs mentioned above, you need to ensure that your network, VPN, firewall, or proxy fully supports the WebSocket protocol. You can read more about WebSocket support in this article: WebSockets Support Q&A for System Administrators.
If this doesn’t help, we recommend the following troubleshooting steps, depending on your operating system (Mac or Windows):
