Using the tone detector in Grammarly for iPhone
You can now use Grammarly’s tone detector to assess the tone of your message while writing on your mobile device.
Note: The tone detector is also available in Grammarly for Windows and Mac and the Grammarly browser extension.
To check the tone of your message, follow these steps:
  1. Double-check that you have the Grammarly for iPhone installed and set up.
  2. Open any app and tap on the text field to pull up the keyboard.
  3. Write a few sentences—the tone detector needs at least 90 characters to activate.
  4. Tap the emoji or G icon that appears in the upper-left corner of the keyboard to check your tone:
If you need to switch the tone detector off, open the companion app on your device, go to Keyboard, and toggle off the switch next to Tone Detection.
If you’re on the Free plan, upgrade to one of the paid tiers at www.grammarly.com/plans to access advanced writing features and boost your productivity.
To find out more about Grammarly’s tone detector, go to grammarly.com/tone. To learn how to use the Grammarly Keyboard for iOS, check out this guide: How does the Grammarly Keyboard work on iPhones?
Note: Grammarly’s tone detector is not available in the Grammarly iPhone Editor. If you would like to see this feature within the Grammarly iPhone Editor, go to the Feature Request section to share your feedback.
