Included in: All paid Superhuman and Grammarly plans
Managed by: Admins and members with designated custom roles
Remove members one by one
  1. Go to the Members page.
  2. Check the boxes next to the members you’d like to remove.
  3. Click Remove in the lower-left corner of the page.
  4. In the window that appears, click Remove members to confirm the action.
Note: If you’re a Superhuman suite admin, removing members through your associated Grammarly account will remove them from all application accounts in the Superhuman suite.
Remove members by list
If you have a list of members who should be removed from your plan, you can import it.
  2. Click the three dots icon ⋮ in the upper-right corner and select Remove members by list.
  3. In the window that appears next, click the Download template link.
  4. Add the email addresses of the members who should be removed to the downloaded file.
  5. Return to the previous window and click Choose file.
  6. Upload the file.
  7. Click Review changes.
  8. Click Remove members to confirm the action.
Remove all members who aren’t on a list
If you have a list of members who should remain or be added to your plan, you can remove everyone else.
  2. Click Invite members in the upper-right corner.
  3. In the window that appears next, choose Import list.
  4. Click the Download template link.
  5. Add the email addresses of the team members who should remain in your subscription to the downloaded file. Don’t include the members who should be removed. You can leave the “Name” and “Group” columns empty.
  6. Return to the previous window and choose the Replace the existing member list option. Team members who are not included in the file will be removed from your subscription.
  7. Click Choose file.
  8. Upload the file.
  9. Click Continue.
  10. Click Confirm to apply the changes.
What happens after you remove members
Members who have been removed receive an email notification from Grammarly about this change. They can continue using their existing Grammarly accounts, and any documents stored in their accounts will not be affected. If a member had an individual subscription that remained paused while they were part of your team plan, their subscription will automatically resume.
Their seats remain vacant until you invite someone else in their stead. If you no longer need the extra seats, update your subscription as described in Add or remove seats.
Note: If your organization is using SAML single sign-on, you also need to unassign access to the Grammarly app in your identity provider for team members that you would like to remove.
