Included in: Grammarly Pro, Plus, Business, and Enterprise plans
Managed by: Admins, account managers, and members with custom roles
If you’d like Grammarly to stop flagging a particular spelling as incorrect, you can add specific terms to your organizational dictionary. Adding certain terms to your organizational dictionary will prevent them from being marked as spelling errors.
To add terms to your organizational dictionary, go to the Org dictionary page and click Add entry in the upper-right corner.
You can also upload a CSV file with your terms by clicking Import list.
Note: You can add phrases or entries consisting of multiple words. Entries in the organizational dictionary cannot contain any symbols or punctuation marks except for the apostrophe (' or ’) and hyphens (-).
If you’re an individual Pro subscriber, you can make your subscription work for your entire team. By expanding it to a team plan, you can share advanced features with colleagues, improve productivity, and reduce repetitive writing. You can add more seats on the Members page.
Related articles
